#1 |
![]() Drives: yaris Join Date: Apr 2012
205/45/17 planning to lower with H&R Sport Springs
Hi guys,
Ive been looking around the wheel, tire and suspension forums for some time and noticed that a lot in 17 inch rims are using 205/40/17 tires. I replaced my stock 185/60/15 to 205/45/17 with +45 offset. I was wondering if I will be able to drop this using H&R Sport Springs (approx 1.5in drop) without having rubbing issues? Also, my current fender gap is 5 fingers. I'm looking forward a conservative drop, about 2 fingers. Our hatch is only 6months old and I'll be using my stock shocks. Hope you could give me advice. Thanks! |
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
I believe with that offset, you'll be alright.
I had 215/35/18 with +42 offset before, lowered with tanabe df210 with the stock struts, and I rubbed slightly on the overfender plastic up front on a large dip. |
#3 |
Tanabe's are about 2in drop right?
My friend's yaris sedan is running on the same wheel specs as yours. He's lowered using Tein S-tech 1.9in drop and he's having minimal rubbing (unless whenever he's loaded with 5 adults on board). If I only lower the car by 1.5in, I'm hoping that it will be a safe drop. Our roads here in the Phils. are bad :( |
#4 |
![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
no problem with that setup
#5 |
![]() ![]() ![]() Drives: Toyota Belta Join Date: May 2011
You should be good bro. With the Teins I would recommend the 40s. That's what I'm on.
#6 |
Alright, can't wait to drop the car already! those wheel wells and fender gap are huge! hehehe
| Tanabe DF lower springs | bail_w | Items for Sale by private party | 4 | 05-08-2011 04:15 PM |
| Another rear spring option! Honda Fit springs!! | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 10-23-2009 06:02 PM |
| Which lowering springs should I choose? | Danish Yaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 40 | 03-28-2009 06:56 PM |
| H&R springs | johnnypaseo | Performance Modifications | 1 | 10-01-2007 09:09 AM |
| planning to lower my car | thegame11 | Cosmetic Modifications (Exterior/Interior) | 7 | 03-18-2007 12:49 PM |
