Old 10-03-2012, 12:35 AM   #1
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
What benefit do injectors offer?
I've seen a lot of people talk about running 1zz-fe injectors. What benefit does this offer?
Old 10-03-2012, 02:22 AM   #2
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
I am going to take an educated guess from experience I gathered when I used to mess with Honda's: Since the injector is meant for a larger engine, it outputs more fuel for the given amount of time it told to open and inject fuel. Normally you only run these 'larger' injectors at times you need the fuel, boost, N2O, etc. It's been shown in NA applications that the stock injectors provide more than enough fuel.
We used to do this regularly between D/B/H series motors back in the day on Hondas.
4/20 NEVER FORGET is offline   Reply With Quote
Old 10-03-2012, 07:05 AM   #3
The only people who would run larger injectors are those with either a turbo or supercharger. The injector is basically a solenoid valve with an opening that allows a specific volume of fuel to flow through at a specific pressure. Upgrading injectors without fuel management typically results in incredible rich air to fuel ratios when not in boost, so fuel management is imperative when doing so.
Old 10-03-2012, 08:05 AM   #4
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I was actually going to ask if you changed your injectors in your supercharger install thread.
I have heard that the supercharger runs on the fuzzy edge of needing the larger injectors. I have also heard that if you have done other upgrades (i.e. intake, exhaust, header) that you really need larger injectors with the blitz.
there again, just second hand info from a person that is not boosted so I really don't know.
Old 10-03-2012, 08:17 AM   #5
I didn't change mine. I bought a set of 1ZZ's and intended to, but decided to do some experimentation first to determine if they are really necessary. What I found is that in theory the stock fuel system can provide the fuel necessary for up to approximately 12 psi of boost. The problem though is that the Yaris fuel pressure regulator is not adjustable to increase the pressure, proportional to the boost, to account for the increased pressure in the plenum. I modified a stock Yaris fuel pressure regulator to increase its limit by 6 psi to account for the boost pressure of the blitz. The videos below are ones that I created while doing some of the testing.
The flow rate of the stock injectors / fuel pump are sufficient, but the OEM fuel maps are not, so one has to run some form of piggyback fuel management to override the OEM maps. With the supercharger the included blitz fuel controller does this, but with the US market Yaris fuel maps, we seem to run a bit leaner than the Japan market maps do.
To account for that some S/C users have upgraded their injectors (but typically run very rich when not in boost {which will significantly shorten the lift of the cat}). Replacing the blitz fuel controller with a piggyback, like an AEM F/IC gives more control.
The other issue with the Blitz controller is that it does not have a mechanism for fooling the ECM, when the system is in boost, so the ECM will eventually "learn" about the extra fuel that the Blitz controller dumps in under boost and will "trim" it off. Resetting the ECM on a regular basis (pulling the negative battery cable for a minute) resets the fuel trims.
http://www.youtube.com/watch?v=852N-COD2Ns
http://www.youtube.com/watch?v=pH3mev88hoo
1zz injectors suit the S/C just fine LtNoogie Forced Induction Forum 51 04-30-2016 10:11 AM
FS: DeatschWerks 550cc Plug/Play injectors Tamago Items for Sale by private party 4 06-27-2012 11:11 PM
Technical question about bigger injectors LtNoogie Forced Induction Forum 1 08-14-2009 03:34 PM
