Old 10-03-2012, 05:29 AM   #1
tyrone_yaris
Drives: Toyota Vitz 2007 facelift
Car seems to be sort of choking
Hi,
In the mornings when I switch on the ignition the car seems to be sort of chocking for a few seconds and then the engine runs fine. Only happens in the mornings or in the evenings after work when the car is parked overnight or for a long time say 7-8 hrs.
Otherwise the ignition starts normally in between.
It's a Toyota Belta sedan called a Yaris sedan there. Haven't check the spark plugs as yet though. Battery is fine.
tyrone_yaris is offline   Reply With Quote
Old 10-05-2012, 03:51 AM   #2
tyrone_yaris
C'mon 94 view and no one with a similar problem?
Old 10-05-2012, 01:24 PM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I have a similar problem sometimes, but that's only because I've tinkered with my intake quite a bit.
Check that enough air is getting to the engine. The filter should be clean and all joints between the intake and the engine should be as tight as possible to avoid leaks.
Good luck!
Old 10-05-2012, 01:31 PM   #4
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Sounds like fuel pressure has bled down (fuel regulator not sealing 100% ?).
Try turning the key to the ignition position for a couple of seconds before turning the key all the way to the start position. This should let the pump build pressure.
Old 10-05-2012, 02:04 PM   #5
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
You could also try some Sea Foam or injector cleaner to see if that helps.
Old 10-09-2012, 03:09 AM   #6
tyrone_yaris
Thanks for all your replies ....sis in law had a baby so was busy thru the weekend at the hosp.
@Flipper_1938 I tried what you had said but still that brief struggle after switching it on and then the engine is running fine....
Only happens in the mornings and after the car's parked for a long time
@Sucker face wont injector cleaners cause all the deposits/gunk to end up in the engine or elsewhere causing more probs in the long run? Just wondering....
@tk-421 will try your suggestion and chk that too..thanks
ImportRacer88's Photo Scavenger Hunt ImportRacer88 General Yaris / Vitz Discussion 8 02-28-2012 04:19 AM
enobmort42 - Photo-Scavenger Hunt! enobmort42 Photo-Video-Media Gallery 9 03-05-2009 10:52 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
