Old 10-06-2012, 12:27 PM   #1
thatbryanguy
Drives: Yaris 3dr hatch
Where to plug boomslang harness to draw power?
Title says it all. Low profile 10a fuse for power but where should I plug it in? Tried one open spot under the hood fuse box but it just buzzed when I turned the ignition key and car wouldn't start.
thatbryanguy is offline   Reply With Quote
Old 10-06-2012, 03:59 PM   #2
For ignition switched power for the FIC you can either connect it to the pink wire on the ignition switch or you can use the red wire in pin 28 of the other ECM connector.
Questions and advice required about power upgrading(windows & locks) W.A.S.P DIY / Maintenance / Service 10 07-22-2009 02:59 AM
Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) gaffo General Yaris / Vitz Discussion 28 07-15-2007 07:55 PM
POWER WINDOW POWER SOURCE IN DOOR PANEL? mrrock DIY / Maintenance / Service 5 03-21-2007 06:27 PM
Need Help - Electrical (finding Power) Ayka DIY / Maintenance / Service 7 10-12-2006 11:51 AM
