Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > New England
Old 03-07-2007, 09:12 AM   #1
sambo42xa
Drives: 07 YARIS Automatic/LiftBac/Red
Flat Tire
Ok, seems like its been dead in here for awhile, so I'll start a new thread.
Had a flat the other day (car sat for 3.5 days) before I left for work. Put air in it and managed to get to work later. At work I checked it out and found on the inside groove a small sheet metal or wood screw. Now, I can put a plug in it myself BUT I'm not sure I want to. Why.....you ask? The screw is small in diameter and I don't want to make the hole (once I pull out the screw) any larger to accomidate (did I spell it right?) the plug I put in. So, what do you think....should I say f*** it and go for it with a larger hole so the plug fits or have the garage put in a patch/plug from the inside?? I think I'm going for the garage........................
sambo42xa
Southern, NH
sambo42xa
sambo42xa is offline   Reply With Quote
Old 03-08-2007, 10:09 AM   #2
tl1000s
Drives: None yet
I always had a tire shop fix nail and screw holes. I've never had a problem with a plug leaking afterwards. I figure they do a lot of them, they know what they're doing, and the sealants they use are fresher than the stuff thats been sitting on the Walmart shelf for the past five years.
tl1000s is offline   Reply With Quote
Old 03-12-2007, 06:28 AM   #3
sambo42xa
All set! Had it repaired at a local Tire Warehouse for $19.00! They even removed the tire and put it back on for me.
sambo42xa
Southern, NH
sambo42xa
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 06:29 AM
All season or Summer tire? GabL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 03-10-2007 11:07 AM
yaris takes a blown tire really well dbaxter General Yaris / Vitz Discussion 4 11-28-2006 04:14 PM
Flat tire, totally ruin help David81 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-15-2006 01:54 PM
