Old 10-08-2012, 10:44 PM   #1
CPALK719
CPALK719's Avatar
Drives: 2012 toyota yaris
ebay foglight kits
i see there are many shops/vendors on ebay selling aftermarket 2012 yaris foglights for the L and LE models. Has anyone bought a set of these yet? i was continplating on getting a set. i do realize when you buy ebay parts, you get ebay quality but you can't go wrong for under a $100 bucks.
here's a link to one set i seen on there .
http://www.ebay.com/itm/12-13-TOYOTA...#ht_4159wt_991
2012 yaris L model
2014 wrangler unlimited sport
CPALK719 is offline   Reply With Quote
Old 10-08-2012, 11:26 PM   #2
trdvvti07
Where's my crown?
trdvvti07's Avatar
Drives: 07 self proclaimed TRD Sedan
I've got the yellow k2 set on the way...fingers crossed its not a cluster bomb of fuckin dismay
I am the obvious resolve to the age old question, "What happens when an unstoppable force meets an immovable object?"
trdvvti07 is offline   Reply With Quote
Old 10-09-2012, 12:10 AM   #3
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
The lamps are fine as long as they are DOT stamped.
On my 2012 L, I did not need the included harness, nor the relay or switch.
The car was prewired, I installed the lamps, and covers, then wired 2 wires of a 4 wire switch to jump the purple and green wires of the stalk connector at the bottom of the picture. The other 2 wires were tied to the shifter illumination wires.
Credit to CTScott
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 10-09-2012, 01:16 AM   #4
CPALK719
CPALK719's Avatar
interesting. and you think all these ebay kits are DOT approved?? lol i would think not. i could be wrong. so did you have to remove the front bumper or were you able to get around doing that?
2012 yaris L model
Old 10-09-2012, 01:41 AM   #5
Absolutely Red 12
Asshole
I didn't say they were all DOT. I got lucky, bought mine from Amazon, (Vendor: Kramer America)
Pulled the pins on the upper bumper, pulled out both sides from the fender.
Bumper leaned forward, and I reached down to install the lights.
Found the fog plugs taped to a harness, right next to where the fogs are.
Did not remove anything from the bottom of the bumper.
The only reason I pulled the bumper was that I replaced the headlight bulbs with Philips CrystalVision Ultra 9003 Headlight bulbs, to match the same H11 I replaced in the fogs.
These fogs only come with Osram 3000K bulbs.
Old 10-09-2012, 01:55 AM   #6
CPALK719
CPALK719's Avatar
im still researching. im very tempted in buying a set of these ebay fogs.
2012 yaris L model
Old 10-09-2012, 01:03 PM   #7
Absolutely Red 12
Asshole
$99
http://www.amazon.com/Lights-Lamps-T...ords=yaris+fog
Old 10-09-2012, 08:48 PM   #8
CPALK719
CPALK719's Avatar
how long did it take you to install? and these were dot approved?
also do they have them with the yellow lenses?
2012 yaris L model
Old 10-09-2012, 10:53 PM   #9
Absolutely Red 12
Asshole
SAE not DOT.
Didnt see yellow, just use these:
http://www.amazon.com/Nokya-H11-Yell...keywords=nokya
Bumper side, 15 minutes including new headlight bulbs.
Inside, 20 minutes, removed the lower steering wheel shroud, ran 2 wires from the switch I installed on the left dash cutouts. Tapped into the 2 wires as above.
Old 10-10-2012, 03:08 PM   #10
CPALK719
CPALK719's Avatar
SAE not DOT.
alrighty !!! so you would say the fitment was good though all in all ? yea, im really leaning towards getting set.
2012 yaris L model
Old 10-10-2012, 05:55 PM   #11
Absolutely Red 12
Asshole
Inserts were a perfect fit.
One of the fog lamp ears slides into slot in bumper, and they give you 1 screw for the other side. Add a screw to the ear below the slot for added safety.
Old 10-11-2012, 05:49 PM   #12
CPALK719
CPALK719's Avatar
i went ahead and placed a bid on a set of yellow lens ebay fogs for my 2012 3 door. im looking forward to getting these badboys!
2012 yaris L model
Old 10-11-2012, 06:01 PM   #13
Absolutely Red 12
Asshole
Let us know how it goes.
I think you should have got the clear, and then you could change bulbs as needed.
Old 10-18-2012, 01:03 PM   #14
CPALK719
CPALK719's Avatar
i wont the auction last night, as of today i made payment of $95.99 free shipping. thats not too bad for some fogs. hopefully they should come soon and i'll get started with them
2012 yaris L model
Old 10-22-2012, 07:31 PM   #15
Lerico
Drives: Yaris 2012
Just installed mine yesterday and it works really well. Took me about 1 hour in total. It fits and works just like OEM.
Lerico is offline   Reply With Quote
Old 10-23-2012, 05:58 AM   #16
odg495
odg495's Avatar
Drives: Yaris & Corolla
Just for people like myself, the kind of inept people that burn water and break anything they touch, can you just tell us in more detail how you pulled out both sides from the fender?
Is there a trick to it, or do you simply pull it out as you said? I'm OK with the pins on the upper bumper, so I'm halfway there!
Cheers in advance!
odg495 is offline   Reply With Quote
Old 10-23-2012, 11:48 AM   #17
Absolutely Red 12
Asshole
Cheers in advance!
Now pull the bumper at the fender liners, there are retaining nubs where it meets the fender, there are also retaining nubs under both head lights. A decent tug will remove it, and lean forward, for lights you do not need to remove lower bolts.
It will remind you of a hood (bonnet) being opened on a Mack truck!!
Old 10-23-2012, 11:04 PM   #18
2012 YarisSE
Drives: NCP131
SAE not DOT.
I'm running same brand of light bulb as well for my yaris
2012 YarisSE is offline   Reply With Quote
FEELER: Possible New HID Vendor hydrohopper Cosmetic Modifications (Exterior/Interior) 17 06-11-2010 02:05 AM
WTB: Gauge Cluster w/tach for HB cdydjded Willing to Buy by private party 12 06-09-2010 04:49 PM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 06:26 PM
Toyota Yaris 5 Doors Body Kits k3nn4 Australia 23 05-08-2009 11:28 PM
2009 foglight kits? songa Cosmetic Modifications (Exterior/Interior) 3 12-10-2008 12:58 PM
