Old 10-14-2012, 11:07 PM   #1
4hzyaris
Drives: 2008 Toyota Yaris
Air Bag Light after slight bump on rear end by stupid other driver!
I've been reading a lot about jumpering on the OBD connector to diagnose codes on SRS. My only other question is where the heck do I find this connector? Is this the same connector under the dash where the engine diagnostic tool would go? lil help would be much appreciated, thx!
4hzyaris is offline   Reply With Quote
Old 10-14-2012, 11:10 PM   #2
4hzyaris
also, once i determine which codes are coming up, how do i know what the codes mean? is there a link that tells me what a 31 code means is wrong? ...(or whatever codes i might have?)
Old 10-15-2012, 06:48 AM   #3
Yes it is the diagnostic connector under the dash. Once you get the number or numbers from the flashing pattern, you can check what the codes mean by looking at the SRS portion of the service manual (downloadable from the Micro Image forum):
http://www.microimageonline.com/foru...32-YARIS-FILES
Old 10-15-2012, 08:51 PM   #4
4hzyaris
curious...what is a DTC? manual says it a lot, but never defines it...sorry, never tried anything so complex before
Old 10-15-2012, 08:52 PM   #5
Diagnostic Trouble Code
Old 10-15-2012, 09:18 PM   #6
4hzyaris
500 pages!? aaarggh! do you happen to know what page shows the code meanings? i have a code 32. if not, its ok, I'll keep searching it out on my own.
Old 10-15-2012, 09:33 PM   #7
4hzyaris
i found it. nevermind. but thank you for all your help!!!:)
Old 10-15-2012, 09:40 PM   #8
Sadly, I happen to know off the top of my head that 32 is a failure of the Occupant Classification System and that the DTCs start on page 45.
ctscott
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
