Old 10-15-2012, 04:01 PM   #1
sroberts
sroberts's Avatar
Drives: 2007 Yaris Sedan
Question Shock/Strut replacement questions
Hey guys, long time no post. I am going to replace the shocks and struts on my '07 Sedan. Just had a couple of questions before I tear into it.
Do I access the rear shock upper mounts from inside the car or through the trunk? Its kinda of hard to tell from the outside.
Do I need to remove the cowl to get to the upper mounts for the struts? I have read some do and some don't.
Lastly and I am sure I know the answer but is it necessary to have an alignment done after replacing the struts? Or can I just take note of the mounting of the original. I am replacing them with Monroe struts.
TIA
I am not allowed to put anything here because I do not have any ricey mods on my Yaris....
sroberts is offline   Reply With Quote
Old 10-15-2012, 04:17 PM   #2
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
So, having a hatch, this may not be accurate, but I'm guessing the rears will be accessed through the top, and the fronts, I had to remove the cowl (you get used to it after doing it 3 or 4 times ;) )
As far as alignment goes, give it a hundred miles or so to break in, then have one done.
Good luck!
Old 10-15-2012, 04:24 PM   #3
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
TIA
You dont need to remove the cowl.
A long 6MM allen wrench, with the short end ground down to 1/2" long.
A 17MM deep offset box wrench will both sneak under the cowl to loosen.
Then you can reach your hand in and remove the nut.
I highly recommend spending a few $$ and getting the Tokico Blues.
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 10-15-2012, 08:22 PM   #4
ciscobear
Drives: Toyota Belta
Agreed.
ciscobear is offline   Reply With Quote
Old 10-16-2012, 03:32 PM   #5
sroberts
sroberts's Avatar
Thanks for the responses so far guys. I already bought the struts and got them really cheap. I cant really afford to spend any more.
Still looking to confirm where to access the top mounts for the rear shocks on a sedan.
Old 10-16-2012, 03:39 PM   #6
Unlike the HB which has nice popout access panels to access the shock, I believe the sedan requires removal of the entire side panel in the trunk. A friend with a sedan bitched about how easy the HB guys have it when it comes to rear shock removal.
Old 10-16-2012, 03:40 PM   #7
sroberts
sroberts's Avatar
Thanks WeeYari!
Old 10-16-2012, 04:03 PM   #8
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
yup...that is the case for the rears in the sedan. also, why not remove the cowl? it is easy. I have done it prolly literally 100+ times now. 14mm for the wiper arms and a 10mm for the 8-10 black bolts. You have to remove the wiper motor first before the metal cowl plate and don't forget the wiper fluid hose like I always do upon reinstall! haha.
Old 11-05-2012, 05:18 PM   #9
Absolutely Red 12
Asshole
Because, its not needed!!
test driving 07 yaris on Sun, quick questions rickc New YARIS Purchase Forum 17 08-29-2012 05:25 PM
Shock and Struts Replacement... New Tires Blowtorch DIY / Maintenance / Service 3 07-25-2012 12:44 PM
Yaris Questions Tokiko New YARIS Purchase Forum 21 07-31-2007 07:36 PM
Questions, questions... littlecarlove Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-21-2006 01:42 PM
