Old 03-07-2007, 11:58 PM   #1
blake111887
Yarisonater
blake111887's Avatar
Drives: NAUTICAL BLUE 07 YARIS SEDAN
Send a message via AIM to blake111887
IAT/MAF HP increaser module
ive read the threads on the modules but does any one know of a way to instal this, ive tried a few but all of them ended up with me not being able to connect the iat/maf back onto it's clamp, hope my diagram helps
blake111887 is offline   Reply With Quote
Old 03-08-2007, 12:45 AM   #2
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
Is that for one of those Ebay add 20+ HP for $10 deals?
Nutzoids is offline   Reply With Quote
Old 03-08-2007, 12:51 AM   #3
blake111887
Yarisonater
yea it is i just wanted to see if theres an actual difference in power but cant get the damn thing to fit right.
Old 03-08-2007, 01:06 AM   #4
I really don't see how it can physically fit that way! Either you'd need some kind of pass-though plug, or to splice that into the wires outside of the plug.
Or, don't waste the time and effort on something that's basically proven to be pure BS
Old 03-08-2007, 01:23 AM   #5
blake111887
Yarisonater
true true, ill figure somethin out but, splicing id deffinately outta the question.
Old 03-09-2007, 04:38 PM   #6
soros151
Another question... :D
soros151's Avatar
Drives: Scion tC 06
watching!
*One tire nearer to my goal*
soros151 is offline   Reply With Quote
Old 03-10-2007, 09:23 AM   #7
Yarisagos
If you want to install that resistor, its not a module. Got to love all the idiots on ebay calling it a chip or module, lol.
I am not sure how it suppose to be connected. By your pics, that resistor is being connected in a parallel connection.
Depending how it suppose to work, you got only 2 options.
First options is, the resistor needs to be connected in parallel with the sensor. Just connect the resistor from the back of the connector, if you must, just follow those two wires and you will find a another connector that can be can be plug from the back of the connector, do not go in the front, hehe.
Second option is, the resistor bypass the sensor, and those two wires needs to be remove. Theres small like ears inside the connector, just bend them carefully with a paper clip to remove the crimp pins from the connector. Might need 2 paper clips do it, sometimes there is two ears.
I would guess option two is not the correct way of doing it, and i would bet my money that its option one, because the resistor is suppose to add a offset value to the sensor, not replace it.
Let us know what value is the resistor so others can do it. Paying $15 for a 25 cent resistor that you can buy at radio shack is too much.
Use a meter to ohms out the resistor. Heard its maybe 33k, but not sure. If there color bands on it, let us know what they are. Those colors tells you what value is that resistor.
Good luck, and lets us know how it works with the Yaris.
Yarisagos is offline   Reply With Quote
Old 03-10-2007, 10:33 AM   #8
Yarisagos
One more thing, I did some reading this is what I found.
http://www.angelfire.com/home/SH0ckf..._Debunked.html
Its not worth it, I wouldnt do it with a new car.
Old 03-10-2007, 10:40 AM   #9
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Step one - place part between thumb and index finger.
Step two - flick that POS across the room.
Step three - search the great vendors of this site for some real power adders for you Yaris.
Old 03-10-2007, 11:05 AM   #10
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
One thing to get and stay in your head. There is no such thing as cheap HP. You gotta pay to play.
jdubau55 is offline   Reply With Quote
Old 03-10-2007, 01:24 PM   #11
Kitt
Kitt's Avatar
OMG!!! I'VE FRIED MY ECU!!!!!!
Old 03-10-2007, 01:35 PM   #12
blake111887
Yarisonater
thanks much ppl, highley appreciated. im probably not goimg through with this mod. thanks for the heads up ppl.
Old 03-10-2007, 01:55 PM   #13
Chris07LB
Chris07LB's Avatar
Central lock module m14mclaren In Car Entertainment + Electronics (audio / video / alarm) 0 02-16-2007 06:11 PM
