Old 10-23-2012, 09:16 PM   #1
Bobohhhhhh
Bobohhhhhh's Avatar
Drives: 2007 Yaris Sedan
Rear Defroster Issue - Please Help!
So I noticed that my rear defroster grid hasn't been working the last week or so. Today I did some troubleshooting and came up with diddly squat.
I did a visual inspection of the lines, despite being underneath tint, look in good condition. I then checked all the fuses... according to the wiring diagram there is a 30A for the Def itself, then a 10A and a 7.5A as well which were fine. I even swapped out the 30 with a new one incase I couldn't see the fault. I then took a voltmeter and tested the connection beneath the 30A fuse and got 11.7 VDC but when I poked and prodded the connections in the rear I got nothing on the meter. Could it be a wiring issue from the front to the back? Or could this be a relay issue? I hear it click on/off as I toggle the switch. Im not even sure where the relay is...can it be replaced?
Im lost please help!
Bobohhhhhh is offline   Reply With Quote
Old 10-23-2012, 10:27 PM   #2
The defroster relay is integrated into the body ECU. Check the voltage on the black wire in pin 2 of connector 4F with the defroster turned on. That is the output from the relay.
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
