Old 10-29-2012, 12:05 PM   #1
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
15" to 14" rims
My 08 Yaris has 15" rims and i just installed new snow tires on the car, i have a set of almost new all seasons mounted on 14" rims that were for an 05 Echo sitting in the basement that i doubt i'll ever use on the Echo, i was wondering come spring can any one foresee any problems if i just mount the 14" rims on the Yaris for the summer?
Thanks
Have Yaris will travel..
Old 10-29-2012, 12:39 PM   #2
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
As long as they clear your brakes you should be fine. That should be the only issue. People on here have run 14s before so it is doable. Now depends on that peticular wheel size and offset.
Old 10-29-2012, 01:50 PM   #3
Mongoose7
Drives: 2007 Yaris HB
The OEM 14" rims will fit.
Mongoose7 is offline   Reply With Quote
Old 10-29-2012, 02:16 PM   #4
MUSKOKA800 runs his winters on 14" ECHO steelies. They are fine.
Old 10-29-2012, 05:09 PM   #5
coheed
Drives: 08 BB LB
Im running 14x6 et 36ish with 185/65's with no issues at all even with being slammed.
Old 11-01-2012, 04:13 AM   #6
jambo101
jambo101's Avatar
Thanks ,looks like it wont be a problem..
Old 11-02-2012, 08:54 PM   #7
14's are rolling stock in Canada 06 to 08.5
Old 11-03-2012, 12:38 PM   #8
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I run my winter tires on 14" Mazda Protege steelies. No clearance issues.
Old 11-03-2012, 05:11 PM   #9
MUSKOKA800
MUSKOKA800's Avatar
With 175/65-14 Michelin X-Ice there are no issues except that the chassis is slightly lower to the ground / snow berms / carwash rails. Braking is amazing when compared to the stock alloys or the 18" TRD set-up.
15" to 14" rims jambo101 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 02-25-2010 06:01 PM
WTB: 4 15" alloy rims _Bravo_ Willing to Buy by private party 2 02-19-2010 06:39 PM
Does Toyota reset the speedo for the Yaris that have 14" and 15" rims? detroiter General Yaris / Vitz Discussion 19 05-17-2009 08:46 AM
