Old 11-07-2012, 10:50 PM   #1
jeeper5usa
jeeper5usa's Avatar
Drives: 2011 Toyota Yaris
Accessing Tail Lightbulbs
I'm sorry, but I did a search and just couldnt find pictures of how to access the lightbulbs in my hatchback lights. Does anyone have a link to where I can see how to access my backup lightbulbs? Thanks in advance.
jeeper5usa is offline   Reply With Quote
Old 11-07-2012, 11:02 PM   #2
There is a plastic piece that pops off on either side to give you access. Once you remove it you will see the bulb sockets, which you twist to remove. The back-up light is the bottom one.
Old 11-07-2012, 11:31 PM   #3
jeeper5usa
jeeper5usa's Avatar
Thanks!
Old 02-06-2013, 06:38 AM   #4
darkspruce
Drives: yaris
replacing reverse light
I've twisted the socket but it only moves about 1/8 turn and will not extract when I pull it.I'm nervous about using pliers or screwdriver to lever it in case the plastic breaks.
cheers
darkspruce is offline   Reply With Quote
Old 02-07-2013, 02:26 PM   #5
jcboy
Drives: Sedan 07
oh just use your fingers to twist it. IIRC it twists CCW when removing (CW to put back in)
Pliers or any other item will damage the tabs.
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
LED tail lights installed Cutie Pie #2 Cosmetic Modifications (Exterior/Interior) 10 08-20-2012 11:25 PM
Original tail light without rear fog light for Yaris 3dr 2009-2011 Ot_tO Cosmetic Modifications (Exterior/Interior) 9 08-07-2012 04:27 PM
Tail lights for 09 sedan piepie Cosmetic Modifications (Exterior/Interior) 7 06-03-2009 09:24 AM
FS: Yaris Liftback Tail Lights Stock OEM tekmoe Items for Sale by private party 5 06-15-2007 11:57 PM
