Old 11-13-2012, 04:58 AM   #1
tyrone_yaris
Drives: Toyota Vitz 2007 facelift
Yaris hatchback vs Sedan weight difference etc.....
Hi,
Just wondering is there a difference in weight etc between the yaris sedan and hatchback also called Vitz (hatchback) and Belta (sedan) here. Out here in our part of the world there is a general perception that the Sedan is underpowered due to the boot space and hence a heavier and extra load on the engine both of which are 1000 cc 1KR FE. Btw....both cars have the same engine specs here in the 1,000 cc category i.e. the 1KR FE engine. There are also 1300 cc variants too.
However, I have driven and owned both cars (hatch and sedan 1,000 cc engine) and found no difference in the pick and drive whatsoever. In fact I find the sedan mre responsive and powerful.
Surprisingly I have noted that both the cars have a curb weight of 990 kg
Anyone else care to add some info / experience they have using either of these wonderful vehicles?
Tyrone
tyrone_yaris is offline   Reply With Quote
Old 11-14-2012, 04:53 AM   #2
tyrone_yaris
Hmmm...no one with any feedback / input???????
Old 11-14-2012, 11:39 PM   #3
tyrone_yaris
Hellooooooo anyone there????????
Old 11-14-2012, 11:53 PM   #4
nookandcrannycar
I've never driven a Yaris sedan. I've never felt that my Yaris hatchback is underpowered....perhaps partially because of the manual transmission. I had a Suzuki Swift with a manual transmission before the Yaris and I always felt I could get enough power from downshifting. We don't have a choice of engines for the Yaris here in the U.S. (1.5 L only), and the sedan hasn't been available for individual cutomers since the 2010 model year (if I'm not mistaken). I widh we had engine choices. I'd go for the 1.0 if it meant a 10% bump in MPG, but that size engine hasn't been enormously popular in the U.S. in the past.
Old 11-15-2012, 12:09 AM   #5
tyrone_yaris
Thanks for your feed back. Here we have the 1.0 L and 1.3 L both in the hatchback the subcompact sedan. Also have the 1.5 RS in the hatch back too
Old 11-15-2012, 09:56 PM   #6
screenprintr
screenprintr's Avatar
Drives: 2010 Toyota Yaris
Since I've never driven anything other than the Sedan I don't know either. Believe you mentioned the Hatchback has more power.
I'd hate to be driving these little Go-Carts full speed and run into an 18 wheeler. It would be like a bug hitting my car.
screenprintr is offline   Reply With Quote
Old 11-15-2012, 11:32 PM   #7
tyrone_yaris
Lol...what versions do you guys have there. Here we have the 1.0L, 1.3L in both sedan and hatch back. The hatchback also has an RS version 1.5L
Old 11-15-2012, 11:57 PM   #8
2o6
Drives: 2007 Liftback
Just the 1.5L in the USA.
The Sedan is slightly heavier than the Hatchback, but it's more aerodynamic and has a longer wheelbase than the hatchback. Performance is roughly the same with either. Sedan might be a bit better on the freeway; at least the ride is.
2o6 is offline   Reply With Quote
Old 11-16-2012, 12:08 AM   #9
tyrone_yaris
Oh ok ...thanks 2o6
Old 11-16-2012, 01:47 PM   #10
Chuck G
Drives: 2010 Yaris Sedan
Drove both & the sedan felt more stable at higher speeds.
So this would make sense.
Old 11-16-2012, 04:45 PM   #11
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
There is a thread sticky with specs of both cars
Originally Posted by sw07gt
Old 11-17-2012, 05:07 AM   #12
b20vteg
no show, no go :(
b20vteg's Avatar
Drives: 2012 yaris 3dr hb
i do. i think it's the gearing though. second feels extremely long...
b20vteg is offline   Reply With Quote
Old 11-17-2012, 08:37 PM   #13
AGlobalThreat
Drives: 08 Sedan & 11 5-door
I have a 2008 sedan with 85000 miles and a 2011 5-door with 14000 miles. My sedan handles better than my 5-door.
There's so many variables though. They would need to have the same tires+pressure, alignment, same suspension wear, same amount of gas in the tank, etc. to get an accurate comparison between the different chassis.
AGlobalThreat is offline   Reply With Quote
Old 11-17-2012, 10:06 PM   #14
bestyaris
Drives: Polar White 4 Dr
I drive sedan, so can't comment on HB.
I assume, HB is light (than sedan) so it should give better MPG?
I would take 1.0 over 1.5 any day... even it give 0 to 60 in 20s...
Yaris is not a fast car to start with..
2007 Yaris Base Sedan
bestyaris is offline   Reply With Quote
Old 11-18-2012, 10:22 AM   #15
MUSKOKA800
MUSKOKA800's Avatar
This topic was discussed back when I first got my sedan. Then, Toyota listed the sedan as a few kg lighter than the sedan. Cannot recall the exact amount but it wasn't significant.
Old 11-18-2012, 04:02 PM   #16
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
I compared the 2010 models. IIRC, the sedan is about 100 lbs. more than a hatch, but the sedan is more aerodynamic and gets a little better MPG.
DebbyM46227 is offline   Reply With Quote
Old 11-18-2012, 04:55 PM   #17
jayeh
Drives: '08 Yaris LB
I've got the AT and find the throttle too damn touchy. I've driven all kinds of vehicles but find my damn yaris the hardest to control the throttle. It was a month of learning to get used to it.
jayeh is offline   Reply With Quote
Old 11-18-2012, 09:33 PM   #18
Kar98
Drives: 2011 Scion tC
Yikes, no way. Before the Yaris, I had a Golf with the 2.0, and I'm missing that half liter very much.
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
Yaris Curb Weight, difference LB vs Sedan CASTREX General Yaris / Vitz Discussion 14 12-12-2006 09:50 AM
