Old 11-16-2012, 02:40 AM   #1
TrYaris
TrYaris's Avatar
Drives: Racin' yaris :D
Voxx Racing 17"
I have those wheels for the next summer, they are 17" Voxx racing 225/45zr17
and I wonder if they will fit on my yaris 2008 HB :o would I need to buy spacers because they are 215?
TrYaris is offline   Reply With Quote
Old 11-16-2012, 03:11 AM   #2
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
doubt it. I run 225/45/15.. only rubs in really tight turns.. I am also really low on coilovers.
-Derrick-
Old 11-16-2012, 09:19 AM   #3
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
If you're dropped that could rub but why not just get smaller tires?
Old 11-16-2012, 10:15 AM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
What is the offset?
Old 11-16-2012, 12:23 PM   #5
TrYaris
TrYaris's Avatar
What is the offset?
I think its 17x7
Old 11-16-2012, 12:49 PM   #6
ilikerice
ilikerice's Avatar
offset is the ET.. usually +42 or maybe even +45
-Derrick-
Old 11-16-2012, 01:00 PM   #7
TrYaris
TrYaris's Avatar
215/45zr17
Old 11-16-2012, 01:32 PM   #8
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
lol
Old 11-16-2012, 01:53 PM   #9
1.5
Form>Function
1.5's Avatar
TrYaris turn the wheel around and look at the inside. You should see etched into one of the spokes, a little box with a number in it. To the left or right you will see the letters ET. That is the distance in mm that the mounting point of the wheel is spaced from the geometric center of the barrell.
You keep giving us
1. the rim diameter in inches= 17
2. the rim width in inches= 7
3. the tire width in mm= 215
4. the tire profile which is a percentage of the width= 45% (45% X 215MM = 96.75MM)
Old 11-16-2012, 01:56 PM   #10
TrYaris
TrYaris's Avatar
ET 42, And sorry its 225 not 215..
Old 11-16-2012, 02:07 PM   #11
1.5
Form>Function
1.5's Avatar
17x7 +42 should be ok but 225 is a fat tire so you may get some rubbing especially when turning.
I would get a smaller tire for a 7" wheel but that is up to you.
Are you at stock height? If you are then you might not have any rubbing at all.
Old 11-16-2012, 02:11 PM   #12
TrYaris
TrYaris's Avatar
I'm totally stock, I didnt change anything on my yaris exept that I have a ShortRam
Old 11-16-2012, 02:20 PM   #13
1.5
Form>Function
1.5's Avatar
should be fine then. test fit them
Racing Simulator escotric Off-topic / Other Cars / Everything else Discussions 1 12-16-2024 05:12 AM
For Sale: Enkei 17" Racing rims & Borla Stainless Exhaust MicaYaris Items for Sale by private party 2 05-06-2011 11:46 PM
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
