Old 11-18-2012, 10:24 AM   #1
bechdan
Drives: yaris colour collection 1.0 vv
advice please - click when accelerating or decelerating
Toyota yaris 2003 1.0 vvt 82k miles
There have been a few issues from the driver side so Ive only been working on this side. I needed to replace the wheel bearing, drive shaft and wishbone which have all been done. The problem that has arisen now is that there is a single click noise when the car speeds up or slows down quickly, or when changing down a gear.
Normally Id be thinking its a cv joint or one of the lower arm bushings but these are all new.
Can anyone suggest any other cause?
bechdan is offline   Reply With Quote
Old 11-18-2012, 10:42 AM   #2
mr_miles
Drives: 2013 Yaris
Check and make sure your suspension is nice and tight. It could be shifting slightly.
Old 11-18-2012, 11:41 AM   #3
bechdan
how?
how do you mean suspension is tight?
Old 11-19-2012, 01:03 AM   #4
mr_miles
Drives: 2013 Yaris
check the top mount bolts underneath the cowl if you can, and remove the front tires and make sure everything holding the hub on is tight also.
Old 12-20-2012, 02:48 PM   #5
bechdan
solution found
It as simply that I had not tightened one of the ball joints up enough. whew.
Advice on First Mods? Condooo Performance Modifications 27 05-21-2011 11:08 AM
General service/maintenance advice dweaver3481 DIY / Maintenance / Service 2 03-14-2011 11:06 AM
Ordered some wheels, need advice on tires 47_MasoN_47 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 04-21-2010 04:56 PM
Good advice for new car owners... YarisSedan General Yaris / Vitz Discussion 10 04-15-2009 03:43 PM
Legal advice needed Rahxephon Off-topic / Other Cars / Everything else Discussions 8 09-24-2007 04:56 PM
