Old 03-11-2007, 06:01 PM   #1
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
FINALLY installed my amp\sub
Well I spent about 4 hours today tearing apart my Egg. Finally finished up the install. I ended up putting the amp in the rear where the right hand storage tray would go. I just moved the jack and jack handle over into the left storage tray. Fits great side to side, but I'm going to have to get some velcro to keep it from moving front to back. I put the sub on the left side of the rear deck. Looks pretty smooth and still retains about 3/4 the trunk space. The worst part was trying to get the rear panels off enough to get the the rear speaker plug so I could tap into the rear speaker wires to go into my hi-level input on my amp.
jdubau55 is offline   Reply With Quote
Old 03-11-2007, 08:05 PM   #2
Razr
YRS WHOR
Razr's Avatar
Drives: White 2007 Yaris E-Limited 5dr
C'mon, get some snaps!
Razr is offline   Reply With Quote
Old 03-11-2007, 08:09 PM   #3
jdubau55
Would if I had a decent cam and it wasnt dark out. Will try to snap some with my phone. The wires arent very neat, but will prolly stay that way in case I ever want to transfer the system over I'll have enough wire to do so.
Old 03-12-2007, 05:08 PM   #4
jdubau55
Took some pictures today. Sorry, I took them with my phone so...you get what you can. The amp is held in with a few strips of industrial velcro on the bottom. It fits pretty snug side to side. Almost perfect actually. The sub isnt secured but its pretty tough to move in due to the carpet on carpet. It's almost like velcro.
Old 03-12-2007, 07:26 PM   #5
Razr
YRS WHOR
Razr's Avatar
Hrmm, you have an entirely different rear floor and back seat to me.
Is the amp screwed down? Last thing you'd want is to stamp on the brakes and have something short out.
Also, have you exprimented with the sub position to see what effect it has on vehicle loading? If not, try tipping it up so the sub itself is vertical and firing towards the rear of the car - you might get a nice surprise :)
Old 03-12-2007, 09:02 PM   #6
jdubau55
I wish I could get it firing towards the rear. Unfortunently it is too tall to sit up with the rear cargo cover on. I want to keep it on there to keep the sub out of view of prying eyes. I may just put it so the fat end is towards the seat so it at least tilts towards the rear. The amp is not screwed down, but is velcro'd. It would take a lot of braking g's to break the shear force of the velcro. Its plenty secure I made sure of that. I think I may move the sub more towards the center and facing more rearward. Due to the hatch design I could almost tell where the sub was in the rear, which I don't like at all. A custom box would be ideal but I don't have the $ for that nor the proper tools to make a decent one.
I have the non split seat. So maybe you have the split one. The rear floor has the "Yaris" cargo mat in it that some don't. It's just a big piece of carpet.
Old 03-13-2007, 09:54 AM   #7
earljail
earljail's Avatar
Drives: 07 Yaris Hatch 5speed
Too bad- it might be louder firing toward the rear.
The amp is not screwed down, but is velcro'd. It would take a lot of braking g's to break the shear force of the velcro. Its plenty secure I made sure of that. .
It isn't the braking force you need to be worry about- it's the accident force... A sub box in the back of the head would kill you. Also, bolting it down makes it harder to steal.
I know custom boxes are expensive, but when you can afford it, try to find a "wedge" shaped box meant for hatchbacks. Some car audio stores carry premade ones just for hatches. Obviously, you'ld have to measure the height.
Old 03-13-2007, 04:11 PM   #8
jdubau55
Well, right now if the sub can jerk the speaker wire out, go through the cargo hatch, up over the rear seat, and still fly and hit me square in the head....the crash would be so severe the sub box hitting me would be the last of my worries. Im gonna go outside and mess with it some more this evening.
Old 03-13-2007, 05:04 PM   #9
earljail
earljail's Avatar
That's probably true!
Old 03-13-2007, 06:21 PM   #10
jdubau55
Did some tweaks. Stood the sub up so it faces the rear. As long as the hatch isnt open its fine. When I open the hatch though the sub makes the left side of the cargo cover pop off the knob. Oh well, it sounds better. Also tweaked the HU and gains on the amp a lil bit to put the bass more in where I usually listen to the volume at.
Old 03-13-2007, 07:47 PM   #11
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
boom boom boom!
2007 Yaris RS Hatchback Black Sand Pearl 5DR MT
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 03-14-2007, 02:05 AM   #12
bido4
Drives: o6 Yaris S
nice nice. what amp have you got in there? is there enough ventilation for it also? i was thinking of putting my amp in that exact same spot, but ventilation was my worry. you should bolt it onto the seat.
bido4 is offline   Reply With Quote
Old 03-14-2007, 02:06 AM   #13
bido4
Drives: o6 Yaris S
ohh and i want that carpet that says yaris on it! LOL
whats your ICE setup ?
Old 03-14-2007, 10:45 AM   #14
sqcomp
Roadrunner Jr.
sqcomp's Avatar
...onto the seat? How about under the passenger's seat with some locking door casters to make it easy to retrieve it and make adjustments?
― Thomas Paine
Old 03-14-2007, 07:17 PM   #15
jdubau55
I think it will be fine where it is. I have some spare computer vent fans I can put in there to stir the air if it ever cuts off due to heat. Def not on the seat. Im not screwing anything to the car. I want stuff that isnt permanent.
The Yaris carpet is part of the Convience package I asume. Custom fit carpet mats all around.
Old 03-15-2007, 09:41 PM   #16
JustYYaris
Drives: 2007 Blazing Blue Hatch M/T
Nice setup, is that a infinity sub?
JustYYaris is offline   Reply With Quote
Old 03-15-2007, 09:51 PM   #17
jdubau55
Indeed it is. Kappa Perfect 10....I think. Its pretty old.
Old 03-16-2007, 10:34 AM   #18
sqcomp
Roadrunner Jr.
sqcomp's Avatar
One of Infinity's better products IMHO.
― Thomas Paine
Finally got some work done on the Yaris! archer1975 Photo-Video-Media Gallery 22 02-21-2007 10:35 PM
System is installed! Venom In Car Entertainment + Electronics (audio / video / alarm) 14 01-28-2007 06:06 PM
Finally! KittenRD New YARIS Purchase Forum 6 01-01-2007 09:16 PM
Finally installed oem ebay fog light for hatchback Adriaan General Yaris / Vitz Discussion 6 12-27-2006 04:24 PM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
