Old 11-19-2012, 01:27 PM   #1
Blue Beast
Drives: 2010 Yaris 3 door hatchback
Mobil 1 vs. regular oil switch at 30,000 miles
Anyone out there know if it's ok to switch over from factory Toyota oil to Mobil 1 with 30K on the odometer? With all my previous vehicles I'd always switched over at 5000 miles or just after break in oil is due for 1st oil change. I have heard or been advised against higher mileage conversion to synthetics because of potential engine seal problems of which I currently do not have any problems with.
Thanks!
Blue Beast is offline   Reply With Quote
Old 11-19-2012, 03:55 PM   #2
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
30,000 is not high mileage. 30,000 is very low. Go ahead and switch.
Old 11-19-2012, 08:20 PM   #3
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
high millage is above 120k miles and anymore with the current standards that keeps raising.
I switched my oil to Royal Purple at 35k, no problems. Seal issues come from high mileage due to ware and the general drying out of rubber based seals, so no issues should arise unless the seal is all ready faulty or leaking.
Old 11-20-2012, 06:41 AM   #4
bronsin
bronsin's Avatar
SAve money and run regular motor oil with the recommended change intervals. Your car wont last any longer with synthetic oil. You wont get better mileage (try it and see I did). The engine will last 150,000 miles or more and in fifteen years the rest of the car will be shot and uneconomical/inconvient to fix every three months.
Old 11-20-2012, 07:05 AM   #5
b20vteg
no show, no go :(
b20vteg's Avatar
Drives: 2012 yaris 3dr hb
he's doing it for the power. yes, mobile 1 makes power. all .25hp...
b20vteg is offline   Reply With Quote
Old 11-20-2012, 07:39 AM   #6
wildcard
wildcard's Avatar
Drives: 09 3dr HB 5sp
Your wallet will definately be lighter, so theoretically you will go a little faster with the switch.
wildcard is offline   Reply With Quote
Old 11-22-2012, 11:51 PM   #7
b20vteg
no show, no go :(
b20vteg's Avatar
haha.
Old 11-25-2012, 10:42 PM   #8
swidd
Drives: Yaris HB
I switched to Mobile 1 at 30,000 miles because I ran out of free oil changes at the dealership. Been running to 101,000 fine. Not that much money if DIY anyway. $35 vs. $20. Big deal.
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
SHELL : regular motor oil : $1.99 a qt. @ RITE-AID . gid DIY / Maintenance / Service 10 01-23-2009 12:02 AM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
