Old 12-02-2012, 12:01 PM   #1
blugraphic
Drives: Toyota Yaris 2007
Toyota yaris 2007 electric windows problems
i just bought a yaris and the back window slide down but stopped sliding up, then after some time the other windows stopped working ! i dunnu whats happening , i washed the car and all these problems happened after, may this have to do something with the problem or is it something else.
any suggestion guys ?
blugraphic is offline   Reply With Quote
Old 12-02-2012, 01:43 PM   #2
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Sometimes the windows come off their guides. I would recommend talking off the back door panels and checking to see if they are still in their guides.
Big Dave
Indianapolis, IN
Old 12-02-2012, 04:36 PM   #3
Start by checking the 30A POWER fuse in the fuse panel that is behind the storage pocket to the side of the steering wheel. It is a large square fuse, rather than one of the little micro fuses.
It is likely that the mechanical failure of the rear caused the fuse to pop, which is now preventing the rest from working.
Old 12-24-2012, 11:57 AM   #4
Blue Beast
Drives: 2010 Yaris 3 door hatchback
On my 2010 three door hatchback the power window on passenger side will not go down with either door switch, might that be a simular fuse issue caused by a mechanical failure? I have 35000 miles do you think that problem will fall in to 36000 warranty service?
Blue Beast is offline   Reply With Quote
Old 12-24-2012, 01:07 PM   #5
It's not a fuse, since it is not all windows. I would think that it would be covered by warranty.
Old 12-27-2012, 11:26 PM   #6
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I have an appointment tomorrow for a recall on my 08 Yaris sedan they are saying some yaris's are having problems with power windows not functioning properly, not sure what the problem is but you might look into the recall for faulty power window operation..
Have Yaris will travel..
electric window, electricity, yaris
