Old 12-04-2012, 03:06 PM   #1
soloecho2
soloecho2's Avatar
Drives: 2004 Echo HB
Auto vrs Manual engine
Does anyone know if the auto equipped engine has the provision for the pilot bearing required for a manual transmission ? I have a line on a newer motor but its an auto. If it doesn't have the provision it won't work. Please let me know.
soloecho2 is offline   Reply With Quote
Old 12-04-2012, 04:08 PM   #2
There is no difference between a block that comes out of a MT car versus an AT car.
Old 12-04-2012, 07:02 PM   #3
soloecho2
soloecho2's Avatar
I was referring to the crankshaft pilot bearing.
Old 12-04-2012, 08:43 PM   #4
Everything up to and including the flywheel is the same for both. You can either bolt the torque converter to it or the clutch to it.
Old 12-04-2012, 09:56 PM   #5
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
or throw in the third option and attach a generator to it and have it power cells and then use the cells to power electric motors and call it the little engine that can. :D
Old 12-05-2012, 07:06 AM   #6
bronsin
bronsin's Avatar
WOW that would be worth knowing except for the fact Im unlikely to put 100k miles on my Yaris in the next 30 years.
Hopefully I wont need another engine!
1kr-fe engine wiring boothybunch DIY / Maintenance / Service 0 03-28-2011 03:59 AM
two questions (relating to manual vs. auto) osmoq New YARIS Purchase Forum 0 05-19-2010 05:40 PM
Manual vs. Auto Transmission j996tt General Yaris / Vitz Discussion 30 02-25-2010 12:43 AM
Handbrake question (Manual vs. Auto) Chaad32 General Yaris / Vitz Discussion 31 07-30-2006 07:03 AM
