Old 12-04-2012, 04:20 PM   #1
petyanca
Drives: 09 LB, 3 door, auto
sway bar is bad for the tires
I installed a 23mm sway bar a couple of months ago, I love how the car drives now, but I've noticed that the tires started to peel off pieces, like skin flakes. I think its because I take turns about 50% faster now.
petyanca is offline   Reply With Quote
Old 12-04-2012, 04:47 PM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
*first in line to buy petyanca's swaybar!* :P
Old 12-04-2012, 04:48 PM   #3
ah. So the driver is bad for the tires -- not the sway bar. I have the same problem. Had me worried there for just a second.
Old 12-04-2012, 05:30 PM   #4
justjesus
justjesus's Avatar
Drives: 2008 Liftback
LOL
that is some funny stuff.
Drive smoother, Garm!
Old 12-04-2012, 05:34 PM   #5
petyanca
Driver or not, car allows for faster turns now, but tires become the weak link. I still have stock tires, they are a harder compound tires but ok for now. When they wear off if I put softer tires on would they do better in terms of peeling off flakes?
Old 12-04-2012, 05:56 PM   #6
vten
u need a Big Brake kit ! to slow you down on the corner .
Old 12-04-2012, 06:19 PM   #7
^ You're supposed to be done with your braking in the turns.
Old 12-04-2012, 06:23 PM   #8
tk-421
tk-421's Avatar
Drives: 5D-07-LB
That might be your real problem. Stock Potenzas suck pretty bad.
Old 12-04-2012, 07:11 PM   #9
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
yea the OEM tires are a softer compound and don't last very long, mine wore out in under 25k miles. partially because the place i used to live had 180 degree turn to get in, it was fun :D
Old 12-07-2012, 09:03 PM   #10
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
my RE92's lasted almost 60,000 miles
Old 12-07-2012, 11:20 PM   #11
Driving behavior makes all the difference.
Old 12-08-2012, 10:07 PM   #12
CoryM
Drives: 2009 5-door, 5-speed
Sounds like you are "chunking" your tires. Basically overheating the tread and it comes off in chunks/flakes. This is why performance tires have less tread depth than all-seasons. End of the day, anything you do to reduce the chunking (tire pressure, neg. camber, better tires, etc) will make the car corner faster.... and wear tires faster! If you are worried about tire life, slow down.
Cheers.
Cory
PS: I figure if you don't put tires on your fun car no less than every two years, you aren't having enough fun. Then again, I use R-comps for street tires....
Old 12-09-2012, 01:08 AM   #13
Flipper_1938
Back before I ever heard the term drifting (early 90's), I used to go through a bunch of tires on a hot rodded camaro z28.....from brand new to belts showing in about a month. I had lots of fun!
Old 12-09-2012, 01:24 AM   #14
b20vteg
no show, no go :(
b20vteg's Avatar
Drives: 2012 yaris 3dr hb
hahaha
b20vteg is offline   Reply With Quote
Old 12-09-2012, 05:36 PM   #15
yariseggvvti
Drives: Yaris Hatchieback
Its all depend on what rate of tire you get and how you drive it. I got Pirelli P4 all season and it last me for long time. High speed and hard corner no problem. I got 5 bars in the rear. No body roll at all.
yariseggvvti is offline   Reply With Quote
sway bar, tires
My Ultra Racing rear sway bar install CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 49 03-03-2011 03:08 AM
TRD Rear Sway Bar detroiter Items for Sale by private party 15 08-05-2009 02:01 AM
sway bar... Toyota dealers must be insane! RedRide General Yaris / Vitz Discussion 10 07-24-2009 04:39 AM
Sway bar and struts DOMAV Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-17-2009 03:26 AM
TRD sway bar and tire wear Cutie Pie #2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 02-01-2009 09:07 AM
