Old 12-05-2012, 10:12 AM   #1
detroiter
detroiter's Avatar
No muffler?
I was reading through old threads and people talked about running no muffler. Seems like quite a few of those people stated the Yaris sounds pretty good actually without the "pumpkin" muffler (as long as your running stock everything else). Is there any downsides to this besides being a bit on the louder side of things? How hard is it to take off the muffler aside from the two bolts that connect it to the midpipe?
Old 12-05-2012, 10:23 AM   #2
^ How about poking your head under there and looking?
There are two rubber hangers as I recall, plus the two bolts. No downside.
Pretty sure those who deleted added a pipe - you don't want your exhaust ending under the car.
Old 12-05-2012, 10:30 AM   #3
detroiter
detroiter's Avatar
ROFL I know, I was going to poke my head under there this morning but waiting for the sun to heat things up a little (it's only like 28 over here in Michigan ;)...any suggestions on adding a pipe? I wonder if I could run a slightly longer piece that had a enlarged flange to fit over the midpipe, then just use a metal clamp to keep it on tight. Do you know what size bolts those two are that need to come off?
Old 12-05-2012, 10:48 AM   #4
I remember 14mm but could be wrong on the bolts.
A metal clamp on a metal pipe? hmmm.
Old 12-05-2012, 12:06 PM   #5
detroiter
detroiter's Avatar
Thanks Garm...I don't have a welder or pipe bender so I'm trying to figure out my options for adding a pipe, I'm not really sure
Old 12-05-2012, 03:23 PM   #6
frownonfun
frownonfun's Avatar
Could you not use the same pipe size and and mate the mid pipe and new pipe with some kind of union coupling? Something similar to those silicone boost couplings but that can withstand high temps. I don't know if that would leak but outside of having both ends flanged or welded that's the best I can come up with. You would wanna make sure the pipe is very securely mounted, though. Not sure the best way to hang it to those rubber things without some welding also.
I crush you like tiny clown car, because you are clown, yes?
Old 12-08-2012, 04:25 PM   #7
MUSKOKA800
MUSKOKA800's Avatar
Removal = releasing two bolts at the junction and unhooking from two hangers.
Go to a muffler shop and have a replica pipe (without pumpkin) created and installed.
If it sounds distasteful you can just switch back yourself without to much sacrificed.
Muffler paveovisual Central and South America 17 05-18-2011 04:43 PM
modify stock axle back muffler what do you think AND189 DIY / Maintenance / Service 15 12-21-2009 07:23 AM
Rusty Muffler dadi_oh Cosmetic Modifications (Exterior/Interior) 7 07-03-2009 08:45 PM
Aftermarket muffler. THiS KiDD Performance Modifications 17 11-12-2008 09:00 AM
Rusty Muffler Hangers YAR1S General Yaris / Vitz Discussion 14 10-24-2008 07:22 PM
