Old 12-08-2012, 10:28 PM   #1
rider99
Drives: 2007 yaris sedan
overdrive
I have a 2007 Yaris sedan with 140,000 miles it has an automatic transmission. My question is that no matter what the outside temp. is here in Louisiana it does not like to shift into overdrive in the morning(worse) or started after 8 hours of rest. I am certain that this has became noticeably different than the previous years. Is there something I should have checked? a/t oil never changed
rider99 is offline   Reply With Quote
Old 12-08-2012, 10:51 PM   #2
tripleyaris300
1.5L
Drives: 2009 Yaris
This is same as my Yaris with 72k miles on it and on my other yaris with 38k miles. It seems like the computer is programmed so that the engine warms up as fast as possible to reach its normal operating temp to save fuel.
tripleyaris300 is offline   Reply With Quote
Old 12-08-2012, 10:57 PM   #3
rider99
could the thermostat be stuck open?
Old 12-08-2012, 11:53 PM   #4
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
the light on your dash goes out at 130 degrees Fahrenheit, normal operating temperatures for internal combustion engine are between 178-215(don't remember exact but around there). our little 1nz-fe appears to go from 184-204(at least that is what my gauge reads) the priority in today's vehicle is emissions first, so the engine has to get warm enough to burn of more toxic gasses. the engine will make that it's priority before it makes fuel economy a priority (i.e. Overdrive) so it is fairly common any more for features to not be available until the priority list is checked off.
oh the 130 should be when the computer takes over full control because the Oxygen sensor is warmed up.
Old 12-09-2012, 08:40 AM   #5
Both the water temp and AT Fluid temp need to reach a threshold before 4th gear prohibition is disabled. I did some experimentation a while back and figured out how to override it with a momentary switch and resistor. It works perfectly and is very simple to implement:
www.yarisworld.com/forums/showthread.php?t=37691
Old 12-09-2012, 02:38 PM   #6
daf62757
Nothing beats a Toyota!
daf62757's Avatar
When I first got my Yaris, I was concerned but after reading about the systemic process on this forum, I just got used to it.
I don't think I possess the mechanical skills to try and override anything so I will leave it along and just keep on truckin!
Big Dave
Indianapolis, IN
Old 12-10-2012, 03:33 PM   #7
dorman68
Drives: Corolla
Normal operation. My inlaw's Yaris & my old Echo do the same exact thing.
2003 Echo - Auto Trans - 93,000 mi.
dorman68 is offline   Reply With Quote
Transmission shifts hard from 3rd to Overdrive ... Hershey DIY / Maintenance / Service 4 07-25-2012 12:30 AM
FS: NST 20% Overdrive Alternator Pulley MGargano Items for Sale by private party 12 06-05-2011 11:06 AM
FS: 2009 Alternator & Overdrive Alt. Pulley MGargano Items for Sale by private party 9 10-28-2010 07:42 AM
How would you rate the auto trans in the Yaris? detroiter General Yaris / Vitz Discussion 39 08-11-2009 05:08 PM
