Old 12-10-2012, 11:58 AM   #1
imike929
Drives: '13 Super White SE
Where does strut bar bolt to?
Hey guys, sorry the extremely naive sounding question but in installation videos ive seen, read, etc. they all show bolts protruding in the far corners under the hood. I've looked (and maybe I'm missing something) but where how the heck does a sway bar attach in the 12/13? TIA! you guys are always helpful
imike929 is offline   Reply With Quote
Old 12-10-2012, 03:04 PM   #2
The bolts go into extra existing holes in the top of the strut tower.
Old 12-10-2012, 07:51 PM   #3
imike929
Ohhhhh so where the red dots are? [IMG][/IMG]
Old 12-10-2012, 08:17 PM   #4
Bingo.
Old 12-29-2012, 01:35 PM   #5
Twisterboy
Drives: Yaris SR
I am guessing you will have to remove the scuttle panel to install it too.
Davy
Twisterboy is offline   Reply With Quote
Old 12-29-2012, 04:05 PM   #6
Davy
I was able to install mine without removing anything, but you definitely have to get the car off the ground and have a second set of hands.
Old 12-29-2012, 05:36 PM   #7
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
Dumb question: why did you have to lift the car Scott?
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 12-29-2012, 05:38 PM   #8
The bolt goes through the top of the strut tower, so you have to reach up into the wheel well to get up there to get the nut on. I found it much easier with the suspension unloaded.
Old 12-29-2012, 08:40 PM   #9
Shroomster
Shroomster's Avatar
now it makes sense, thanks.
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
Rear strut tower bar problem mrbond Performance Modifications 25 09-22-2009 02:32 AM
Any difference on Tanabe front Strut Bar VS Unknown ebay Strut Bar? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-07-2009 06:58 PM
Strut bar - To preload or not to preload that is the question YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-02-2009 09:38 PM
