Old 03-12-2007, 11:38 PM   #1
critical
Drives: ewdew
i happen to have a 1.8 fuel injector
hi, i happen to have a 1.8 fuel injector 2nd hand imported from japan for use on 1.5 1nz-fe engine, its greenish in color, so far the guys over her in singapore used it on 1nz-fe engine and got quite a hugh gain, i wonder if you guys have tried that before?
critical is offline   Reply With Quote
Old 03-12-2007, 11:40 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
what is the injector out of, I bet I could pull a set out of a Matrix/Vibe for free
Old 03-12-2007, 11:43 PM   #3
critical
Drives: ewdew
most likely the 1.8 corolla or celica
Old 03-12-2007, 11:57 PM   #4
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
A bigger injector is not going to do anything. Adding the injectors by themselves will make the car slower. If you tune for them, it is the same as tuning with the stock injectors. The stock injectors are fine with no power adders.
Fuel Capacity ? ttufrosty DIY / Maintenance / Service 19 08-27-2013 12:14 PM
Increased MPG or HP anyone???? slvryaris Performance Modifications 55 05-27-2007 10:49 AM
higher octane fuel KSIbucky DIY / Maintenance / Service 37 01-14-2007 07:17 PM
My problem with my car; help(gas econ) Lafiro General Yaris / Vitz Discussion 42 11-14-2006 08:32 AM
Consumer Reports on Ethanol Driver General Yaris / Vitz Discussion 6 09-01-2006 11:21 AM
