Old 12-14-2012, 09:01 PM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
Question about drum brakes
How tight does the cover has to be with contact with brake shoes?
I know the star wheel alignment i can adjust it loose/tight, and this will affect the handbrake 'clicks'
but i dont want rubbing which lowers my mpg and damage my brake shoes
so how tight should it be?
thanks
caineroad is offline   Reply With Quote
Old 12-14-2012, 09:45 PM   #2
You want them to spin freely when the pedal is not pressed and the ebrake is off.
Old 12-14-2012, 09:49 PM   #3
caineroad
caineroad's Avatar
But I want my handbrake to have max 2 clicks, is there any other way to adjust this?
If I let the drum brakes to move freely, the handbrake will be 5-6 clicks.
thanks
Old 12-14-2012, 10:12 PM   #4
thanks
Yes. You can tighten the handbrake via the nut at the base of the lever to take up the slack, without making the shoes move.
Old 12-14-2012, 10:34 PM   #5
caineroad
caineroad's Avatar
ooo, got you thanks!!
Rear Drum brakes bankrobber DIY / Maintenance / Service 0 04-17-2010 11:39 PM
Weird question about my brakes brainless twit General Yaris / Vitz Discussion 8 01-22-2009 10:59 AM
Brakes question MeggiemobileSFLA DIY / Maintenance / Service 23 03-16-2007 05:17 PM
Changing drum brakes to discs? eTiMaGo Performance Modifications 5 09-25-2006 04:17 PM
