Old 12-16-2012, 03:21 PM   #1
Hillbert
Drives: 07' Yaris
Plasti Dip Emblems (Pics)
So i've been reading up on plasti dip and i figured i would try blacking out my badges. It is incredibly easy to use. Even though it is December, i had some issues with temperature, and not getting an even spray pattern. Overall i think they turned out just fine.
I started by removing the front emblem, just for ease of coverage while spraying. The first time i attempted to spray the front with the emblem still attached, the plastidip linked between the paint and the emblem and i could not get a clean separation between the two, so i had to start over.
I used a basic degreaser on the rear emblems before i started painting. Next i used painters tape and newspaper to tape up the back. Finally i started spraying away. I did a total of 6 coats, all very light. Then i removed the paper and the tape and slowly peeled away the excess material.
Ive seem another member here has done the mirrors of the car, and i think that will be my next project for the yaris. Once the summer rolls around, im hoping to do some dipping on my Evo!
Enjoy!
Hillbert is offline   Reply With Quote
Old 12-16-2012, 03:53 PM   #2
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
How did you get it off of the car's paint?
Old 12-16-2012, 04:05 PM   #3
Hillbert
Drives: 07' Yaris
All you need to do is get an edge lifted off the paint. You can do it with your finger if its an easily accessible part of the car. If you look at the third to last picture, you can see an edge that has been lifted up. Then you just peel it away, and the gap between the badge and the paint will make a clean tear.
Also if you want to remove the areas within the badges or the holes in the lettering, all you need is a toothpick or a narrow object (preferably something that wont scratch the paint) and then pick at it until it comes off in one piece.
Old 12-16-2012, 08:01 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
Looks good!
Old 12-16-2012, 08:04 PM   #5
TrYaris
TrYaris's Avatar
Drives: Racin' yaris :D
I think I might do this for mine, but in a white-zone color :P Looks really great !
TrYaris is offline   Reply With Quote
Old 12-16-2012, 08:21 PM   #6
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I've been considering doing this in white to match my white dipped wheels but I don't wana lose my stickerbomb.
Old 12-27-2012, 07:09 PM   #7
HANZO_187
#CarFiend-HANZO188
Drives: 2011 Toyota Vios
I'm gonna be doing the same thing the only thing is, is that I got tbe 2011 Yaris (sedan) and to get behind the front emblem is gonna be different. I'm goin all black with mine...Got hub caps and screw it might just paint those too. The car looks great and @1.5 yeah your sticker bomb emblem looks legit never seen any one do that.
HANZO_187 is offline   Reply With Quote
Old 12-28-2012, 07:16 AM   #8
1.5
Form>Function
1.5's Avatar
Emblems are super easy to remove just slide a credit card behind them and pry. On the trunk make sure you're pushing out the clips from inside the trunk.
Old 12-28-2012, 04:30 PM   #9
HANZO_187
#CarFiend-HANZO188
I did the back chrome trim and also did the back emblem now ita just the front one thats left over to do. I wanna pop it out so its easier then spraying it on the front bumper. The only thing is that is that I got a 11' and its grill area is a no access type.
Old 12-28-2012, 04:53 PM   #10
1.5
Form>Function
1.5's Avatar
pics
Old 12-28-2012, 08:55 PM   #11
HANZO_187
#CarFiend-HANZO188
The start of my current project.
Old 01-20-2013, 02:48 AM   #12
iceage
Drives: no car
how do you get the front emblems off?
iceage is offline   Reply With Quote
Old 01-20-2013, 09:08 AM   #13
1.5
Form>Function
1.5's Avatar
Hanzo that came out great!
Ice, I just took an old CC and slid a corner of it behind a corner of the emble. I just really Jimmy'd and wiggled the card back and forth while applying force in each direction and it should eventually pop off.
That is on a sedan.
Old 01-21-2013, 03:08 AM   #14
HANZO_187
#CarFiend-HANZO188
Yep, thats a Sedan. I did the front too and forgot to take a photo of it. I never even took it off just taped around the front grill. I'm stoked cause soon enough I'm gonna have some money stashed away to buy some rims/coilovers soon. Gonna post up the photos of the front when I get it clean up real good!
Old 01-23-2013, 12:17 AM   #15
DJPaneno
Drives: 07 Yaris Sedan
I found that carefully using a pin tool or the end of a mechanical pencil is an excellent way for taking off the excess rubber.
The excess light spray that ends up around the emblems is easily taken off by rubbing your finger along it.
DJPaneno is offline   Reply With Quote
Old 03-05-2013, 02:58 PM   #16
MyzticZ3r0
Drives: 2007 Toyota Yaris Hatchback
I decided to plastidip my front emblem, but while removing it, the plastic inserts that hold the front bumper broke from just pushing in the middle. Can I pick up new inserts at home depot or can I only get them at the stealership?
MyzticZ3r0 is offline   Reply With Quote
Old 03-05-2013, 11:59 PM   #17
jetblast
Drives: Gen 1 XB
Check the Dipyourcar.com vids on Youtube for their new Pearl effect, also the metallizers. Cool stuff.
Why strive for a JDM BB, when you can promote the Scion badge?
jetblast is offline   Reply With Quote
Fun With Plasti Dip Jackalope1 Cosmetic Modifications (Exterior/Interior) 16 06-20-2013 10:16 PM
Plasti Dip imike929 Photo-Video-Media Gallery 2 11-07-2012 06:47 PM
Plasti dip wheels Sam! Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 09-23-2012 03:12 PM
Got a little crazy with the Plasti Dip yesterday.... 07typeS Photo-Video-Media Gallery 23 07-05-2012 09:24 PM
Plasti Dip - Multi-Purpose Rubber Coating eco Performance Modifications 2 12-23-2006 06:45 AM
