Old 12-18-2012, 12:46 AM   #1
Philspecv
Drives: Yaris s
Hid kit on 07 s sedan
Hi everyone I'm having a lot of difficulty getting hids to work. I've gone through several sets of h4 bulbs and have yet to have 1 ignite. This is extremely frustrating! Help! Thanks
Philspecv is offline   Reply With Quote
Old 12-18-2012, 12:59 AM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
try reversing positive and negative for the lo beams
Old 12-18-2012, 01:17 AM   #3
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
This worked for me
Originally Posted by sw07gt
Old 12-18-2012, 01:19 AM   #4
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I went through a lot of trial and error, and a lot of asking CTScott what I was doing wrong - something to do with the lights are operated in reverse: so I guess there's a constant current to keep the lights off, and when you want the lights on the current shuts down.
Old 12-18-2012, 04:33 AM   #5
Philspecv
Drives: Yaris s
Which would those be? I know there's three prongs...the sides? The middle?
Old 12-18-2012, 09:06 AM   #6
vten
You can flip the connector that going into the ballast ..., on my case, using the morimoto h4 harness, I switched the blue and the white wire from the 3 prong to work... We have the thing called " the ground switch"
Old 12-18-2012, 10:27 AM   #7
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I had a problem with mine too but I am a wiring noob and can't even tell you what was wrong lol. Since I got them working I have had no problems.
Old 12-19-2012, 04:59 AM   #8
Philspecv
Drives: Yaris s
*update* tried this and got it to work. Thanks... Only problem is that my halogen highs don't work properly now..
Old 12-20-2012, 02:20 AM   #9
SAV912
Pirate Yaaaaris
SAV912's Avatar
Do you have aftermarket headlights with separate slots for halogens? If you are using stock housings, the low beam xenon bulb is the same that would be used for the high beam.
The high beam lamp will not illuminate in the cluster because the current is different, but if you have bi-xenon headlights, they should still ignite. If you replaced it with a single bulb xenon kit, there are no highs to ignite and thus you no longer have high beams at all.
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
FS:35w HID KIT from REALTEK 8000k wowitswil Items for Sale by private party 4 01-14-2010 02:28 PM
HID Kit ecmiyake DIY / Maintenance / Service 5 12-12-2009 05:21 PM
What is the best HID kit ? waka General Yaris / Vitz Discussion 1 12-03-2009 07:49 PM
To put on PnP HID kit without retrofit, Yes or No? mr.white_hb Cosmetic Modifications (Exterior/Interior) 3 09-20-2009 08:43 PM
