Old 12-19-2012, 11:00 AM   #1
Dirk888
Drives: 2007 Yaris hatchback
Question Wireless door lock vs keyless entry
I just purchased a 2007 Yaris 3D hatchback. It was not sold with keyless entry but when I check on http://www.epc-data.com/. based on the VIN, it says that it has wireless doorlock with a wireless receiver, OEM part # 89741-52240, does this mean that I can easily add keyless entry by buying a FOB & programming it? It has power door locks.
Dirk888 is offline   Reply With Quote
Old 12-19-2012, 11:41 AM   #2
In theory it is that simple. You may want to look behind the panel just below the C pillar on the driver's side to verify that the receiver is really there.
Old 12-19-2012, 07:59 PM   #3
Dirk888
So, "in theory" if the receiver is there, I could buy a Keyless Entry Remote Fob and follow this procedure to program it? (I know you can't make promises)
The driver’s door open and unlocked.
Key out of the ignition.
1. Insert and remove the key from the ignition switch 2 times within 5 seconds.
NOTE: Steps 2 and 3 should be performed within 40 seconds.
2. Close and open driver’s door TWICE.
3. Insert the key into the ignition and remove it.
NOTE: Steps 4 – 6 should be performed within 40 seconds.
4. Close and open the driver’s door twice.
5. Insert the key into the ignition.
6. Close the door.
7. Turn the ignition switch from “Lock” to “On” and back to “Lock” at about 1 second
intervals to select the desired mode:
-1 time for ADD mode.
-2 times for REWRITE mode.
-3 times for CONFIRMATION mode.
-5 times for PROHIBITION mode.
8. Remove the key from the ignition.
9. To confirm your mode selection, the power locks will now cycle “lock” to “unlock” a
number of times corresponding to your key cycles in step 7.
NOTE: If Confirmation or Prohibition modes have been selected, opening the door will
complete the procedure.
10. For Add or Rewrite modes do the following within 40 seconds of Door
Lock confirmation:
A. Press both transmitter Lock and Unlock buttons simultaneously between 1 and
1.5 seconds and release.
B. Within 3 seconds of step A, press the transmitter Lock button for more than 1
second and release.
If the transmitter has been successfully programmed, the power locks will
cycle “lock” to “unlock” once at this time.
If there are problems with the transmitter or the procedure up to this point, the
locks will cycle twice. If this occurs, verify that you have received the correct
transmitter, and then repeat the above procedure.
C. If multiple remotes are to be reprogrammed, repeat steps A and B.
11. Open the driver’s door to conclude programming mode.
Old 12-19-2012, 09:35 PM   #4
Correct
Old 12-20-2012, 12:59 AM   #5
Dirk888
Thanks
Old 01-06-2013, 06:34 PM   #6
sroberts
sroberts's Avatar
Drives: 2007 Yaris Sedan
That is really how you program a new key or you just messing with us, lol? The dealer charges $175 to program a key, I thought it was done with a programmer or something.
I am not allowed to put anything here because I do not have any ricey mods on my Yaris....
sroberts is offline   Reply With Quote
Old 01-06-2013, 06:40 PM   #7
That's how you program the remote. Programming a transponder key (the chip in the key kind) requires the Toyota TechStream system to program.
Old 01-06-2013, 06:54 PM   #8
sroberts
sroberts's Avatar
I see, thank you for the info. I totally forgot about the chip. Does my 2007 Sedan have a chip in the key?
How about the key itself, can a locksmith cut the key or does Toyota have to do that too?
Old 01-06-2013, 08:08 PM   #9
NEexpat
Drives: 2009, auto, 4dr LB
Put your left foot in,
Your left foot out,
Your left foot in,
And shake it all about.
You do the hokey pokey
And turn yourself around.
Now put your right foot in,
Your right foot out,
Right foot in
And then you do the hokey pokey
Turn yourself around,
Now your keyless remote fob is programmed.
I told a friend about this procedure, open the door close the door turn the key to here, turn it back etc. etc. she thought I was joking too.
NEexpat is offline   Reply With Quote
Old 01-06-2013, 08:13 PM   #10
Your 07 does not have the transponder key (you can tell by looking at the ignition switch - Ones without it have a totally metal ignition switch, and ones with it have the inner part that turns metal and the outer part plastic).
Cutting the key can be done by a locksmith without a problem.
Old 01-15-2013, 07:22 PM   #11
sroberts
sroberts's Avatar
Ok, I tried to program my new key today using the above procedure and it's not working. I get to step 9 and the locks cycle once to indicate "add" mode. But after I hold both lock and unlock, then lock. Nothing happens after that. The instructions say that the locks should cycle once if it worked and twice if there is a problem. It does neither for me.
Also, can some one tell me what the different modes are for. Obviously "ADD" means to add a remote? What does "CONFIRMATION", "PROHIBITION", and "REWRITE" modes do?
Thanks!
Old 01-15-2013, 08:44 PM   #12
Thanks!
• Add Mode is used to register new recognition codes
while retaining the previously registered codes. This
mode is used when new transmitters are added. If the
number of registered codes exceeds 4, the previously
registered codes will be erased in order, starting from
the first registered code.
• Rewrite Mode is used to erase all the previously
registered recognition codes in order to register new
recognition codes. This mode is used when the
transmitter or the door control receiver is replaced
with a new one.
• Confirmation Mode is used to confirm how many
recognition codes have already been registered
before any additional recognition codes are
registered.
• Prohibition Mode is used to erase all the registered
codes and disable the wireless door lock function.
This mode is used when the transmitters are lost
Old 01-16-2013, 04:34 PM   #13
sroberts
sroberts's Avatar
Thanks CTScott, that helps a lot!
So I am thinking I got the wrong key fob for my Yaris since I cant get it to program at all. Does anyone know what the correct part number would be for a FOB with electronics for a 2007 Sedan?
Old 01-16-2013, 09:47 PM   #14
89070-52860 or 89070-52730
Old 01-17-2013, 09:44 AM   #15
sroberts
sroberts's Avatar
well poop. I bought a 89070-52730 and it wont program. Any suggestions on why the Yaris wont program it? I followed the instructions exactly, tried it like 10 times.
The description says it must be programmed by a Toyota dealer but I am assuming they would just be performing the procedure listed above?
http://www.amazon.com/Keyless-Remote...433742&sr=8-1&
Old 01-17-2013, 10:19 AM   #16
If none of your remotes work, then the problem may be the receiver, rather than the keys' transmitters.
Old 01-17-2013, 10:23 AM   #17
sroberts
sroberts's Avatar
My original remote works fine, I swapped the electronics into a new shell, the original shell started coming apart. I was hoping to finally after all these years get a second fob so both my wife and I have one just wont seem to take.
Old 01-17-2013, 11:10 AM   #18
The EPC shows the 89070-52730 part as replacing the 89070-52860 one. Perhaps they really are not compatible. If you want, PM me your VIN, and I can tell you what part number came with your car.
Also, inside of the transmitter there should be a label on the electronics. Compare your old and new ones.
For example, the key that I have on hand (that came with a steering column that I bought off ebay for a project), says:
Tokai Rika
MDL B44TA
ETC094LPD0451
05015/POSTEL/2007
2344
keyless, remote, wireless
Keyless Entry stopped working but buttons do work! worduphomes In Car Entertainment + Electronics (audio / video / alarm) 5 01-17-2013 09:35 PM
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
Keyless Entry Remotes are dead... now what? Zanutto General Yaris / Vitz Discussion 7 01-11-2012 05:17 AM
I lost my master keyless entry key, need suggestions.... Frankd1 DIY / Maintenance / Service 19 12-01-2010 11:13 PM
Aftermarket Keyless Entry - How does it affect the Warranty? aerock19 In Car Entertainment + Electronics (audio / video / alarm) 7 09-07-2007 02:11 PM
