Old 12-20-2012, 11:56 PM   #1
OTB
OTB's Avatar
Drives: 2zz MR-2 Spyder
Cruise Control Install Help - ECU Pin
Hi guys,
I'm installing the 2 button DIY cruise control (thanks CT Scott!), and the ecu pin is really getting on my f_____ nerves
I pushed the factory plug out (from the connector side towards the wires side, and I'm trying to push the wire with the square pin thiny in from the wire side, and once the pin is "buried", I can't get any farther, and it just starts to buckle. It doesn't let me get the rubber seal seated, I'm just smashing it.
Any tips would be greatly appreciated, I'm ready to choke someone or something.
OTB is offline   Reply With Quote
Old 12-21-2012, 06:33 AM   #2
Did you release the pin lock (by sliding the while plastic chunk)? Also, are you sure you are inserting it in the correct orientation, per my DIY?
It should go in and click into place very easily.
Old 12-21-2012, 11:33 AM   #3
OTB
OTB's Avatar
A ha!
Thanks Scott,
I was using a different DIY that didn't quite have that much detail. I pulled up yours from microimage and its a whole lot better!
After some troubleshooting, my clutch switch wire taps in the fuse box were shaky, and the ecu pin wure works a whole lot better knowing the pin lock stuff. I hope I didn't compromise the life of that pin trying to cram it in repeatedly!
cheers
sick of working on cars
This is pretty frikken stupid - Yaris '07 LB auto cruise control firemachine69 DIY / Maintenance / Service 10 07-20-2010 08:09 AM
DIY CRUISE CONTROL? rossman DIY / Maintenance / Service 0 07-09-2010 05:00 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
Rostra Cruise Control install done on MT AlexK DIY / Maintenance / Service 34 09-18-2007 03:21 PM
