Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > UK
Old 12-23-2012, 07:13 AM   #1
yasinmz
Yaris 2000 Engine Starting Problem
I have Yaris 2000, where the following seems to be OK:
1. There is no fault code.
2. Engine compressor is OK.
3. Timing is OK.
4. The fuel circulation is OK.
5. The plugs are sparking.
Everything seems to be fine but the engine doesn't start, can anyone help what would be the problem???
yasinmz is offline   Reply With Quote
Old 12-23-2012, 08:07 PM   #2
jRoss
Drives: 2010 5spd sedan
What does it do when you try to start it?
jRoss is offline   Reply With Quote
Old 03-09-2017, 02:53 AM   #3
murtaza319
Drives: Toyota Yaris
hi can anyone tell me about, how to read code in yaris 2000 1sz-fe and tell me about which wire is grounded from ecu to read codes
murtaza319 is offline   Reply With Quote
2000, engine start, problem, toyota, yaris
2002 diesel, problem starting when engine is hot casadelaloma DIY / Maintenance / Service 0 10-18-2010 08:48 AM
