Old 12-28-2012, 04:32 PM   #1
TRDMarty
CTScott, please I need your help
Jeff from MicroImage advised me to seek your advice on wiring of fog lights.
Following the instructions provided in the foggie kit (1st gen instructions) did not have the desired results, lights did not work at all when activating the provided switch. I did unplug the connector (A24)on the engine compartment fusebox and with a 12 volt probe actually energized the foggies and yes they turned on!! Now knowing that, from the fusebox foward to both lights, my assembly efforts do work. The problem appears to be the inside connections.
I called Jeff at MicroImage and he sent me a PDF of a 2nd gen wiring instructions. I made sure the 15 Amp fuse was installed and was not compromised (blown), it is OK. I did encounter the provided switch had a ''always on light'' similar to having your dash lights on. The 2nd gen instructions did provide an image of the aftermarket switch which was disassembled showing a resistor that needed to be removed. I disassembled the switch to look exactly like the image and laid the switch next to the image and called my co-worker over to confirm and he did. I then removed the resistor that was circled in the image and reassembled the switch and reinstalled into the car. After reconnecting, the light still stays on all the time(like before) the light that is supposed come on when you activate the switch now does not work. It appears that the resistor shown in the image could be backward (there are 2 resistors on the switch) and maybe the resistor that is NOT circled in the image could actually be the one that needs to be removed.
FYI, I work in Aerospace full time and when I refer to my co-worker, it is my 2nd job which I work at a shop restoring DeTomaso Pantera's.
CTScott, at this point I had my co-worker review the instructions while looking at my wiring changes step by step and confirmed that its is wired to the instructions. I am open to your advice on this aftermarket kit. However, would installing a factory OEM light stalk be my best move??
Jeff said you might even have one or reccomend as to where to get one before going to the Toyota dealership.
Marty
Old 12-31-2012, 07:17 AM   #2
dindy
metallic green vitos
Drives: 2002 toyota vitz. 1.0 auto
Send a message via MSN to dindy
you mean foglights?
dindy is offline   Reply With Quote
Old 12-31-2012, 07:33 AM   #3
dindy
i used to connect fog lights to my friends. if you want i tell you how i did them.
Old 01-01-2013, 11:03 PM   #4
yaris2010RS
yaris2010RS's Avatar
http://www.yarisworld.com/forums/showthread.php?t=42607
Old 01-01-2013, 11:57 PM   #5
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Yeah, read that! ^
Old 01-02-2013, 06:44 AM   #6
Marty,
Did you wire them for normal operation (where they only come on with the low beams), or for one of the other modes of operation (on anytime or on with highs and lows)?
Old 01-02-2013, 05:12 PM   #7
yaris2010RS
Scott i love your new sig.....
Old 01-03-2013, 08:00 AM   #8
TRDMarty
Marty,
Yes I wired them for normal operation (low beams)
Actually I would prefer to wire them as to where I can turn them on at any time without running lights or headlights.
Any suggestions on this utilizing the provided switch & relay??
Marty
Old 01-03-2013, 08:05 AM   #9
TRDMarty
Marty,
FYI, the kit I installed is the kit from Micro Image and not an E-Bay kit.
Marty
Old 01-03-2013, 08:22 AM   #10
Marty
Can you snap pics of:
1. The wires entering the switch
2. Where you connected each of the "other ends"
3. The inside of the switch
Question for CTScott Dave55 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 03-08-2012 11:55 AM
Update: A little more damage found (CTScott, could use your knowledge here). SilverBack General Yaris / Vitz Discussion 21 10-16-2011 02:47 AM
So, CTScott was just at my house...in San Diego. :) mazilla DIY / Maintenance / Service 14 08-18-2011 11:44 AM
CTScott is a God... Pacquiao General Yaris / Vitz Discussion 25 07-25-2011 04:45 PM
Hard-wire power cable for GPS in 2009 Camry? CTScott, know anything about Camrys? IsLNdbOi Off-topic / Other Cars / Everything else Discussions 6 06-18-2011 08:49 AM
