Old 12-29-2012, 01:26 AM   #1
squrlcage1
Drives: toyota yaris
sickspeed horn boo!
Thought I'd be a good hubby and install two Sickspeed horns on wife's 2010 Yaris for Xmas. Barely a difference, highly disappointed, big waste of money. Any opinions? Suggestions?
squrlcage1 is offline   Reply With Quote
Old 12-29-2012, 08:37 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I'm not familiar with the brand, but I replaced the stock horn with two FIAMM horns (one high, one low). My first attempt was to run them in series to reduce the current draw, but it didn't work right. I ended up running a separate 14ga wire from the battery to handle the current draw and using the stock horn wire to drive an ice cube relay. It's still not as loud as I would like it to be on the freeway, but in an enclosed space it's deafening. Perhaps you could post up an install pic so we can see how you did it?
Old 12-29-2012, 09:25 AM   #3
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
i bought some autozone horn that was rated very loud (based off of a normal, loud, very loud rating) and it turned out to be a clown horn. now my friends laugh even harder. good luck. let us know what ends up working for you.
Club SHIFT
Old 12-29-2012, 10:25 AM   #4
vten
Yup , got the hi/Lo fiamm for my car , sounds good and installation was a pretty easy .
Old 12-29-2012, 01:25 PM   #5
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
air horns FTW....
Old 12-29-2012, 02:34 PM   #6
squrlcage1
I have it wired right from the wire that came off the old horn, then grounded to the chassis. I had to fabricate a little to get horns between the radiator and grill. I also bought the wiring harness ($17) that i didnt even need.
Old 12-29-2012, 02:56 PM   #7
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
These.
Old 12-29-2012, 04:23 PM   #8
Flash K
Drives: 2010 blue sedan
I just today installed 2 auto zone horns. Sounds a lot louder, also sounds like a car horn instead of a bird tweet. "Blazer dual tone, made in Italy, maximum sound, low high" less then 25 bucks. New horn 101 db, old horn 98 db.
Flash K is offline   Reply With Quote
horn, sickspeed, yaris
My horn install... Goose DIY / Maintenance / Service 7 01-29-2016 04:10 PM
DIY Horn Replacement. screenprintr DIY / Maintenance / Service 9 12-29-2012 01:29 AM
where is my horn located? 2007 3 door Suey 1958 General Yaris / Vitz Discussion 6 11-27-2011 09:57 AM
Horn Relay? MGargano DIY / Maintenance / Service 7 11-14-2009 06:01 PM
Toyota Premium Horn Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 22 02-18-2009 11:28 PM
