Old 01-07-2013, 12:28 AM   #1
phaznet
phaznet's Avatar
Drives: '07 Yaris Sdn
Stuck trying to get bolt off!
Today I tried installing some tein s tech springs I got from Garm on my 2007 Yaris Sedan. I successfully managed to install the spring on the front right after many hours! When trying to undo the first nut on the front left side, I managed to strip the thread on the inside!
I went by the instructions on the manual AIM 000 365-3, which I found on these forums somewhere.
In step #2 they show that you only need a 17mm socket. However I found that impossible, the bolt would turn with the nut. I had to use a wrench and an allen key to get the bolt off. I also sprayed the nuts and bolts with penetrating oil to help break down some of the rust. I wasn't as lucky on the other side. I completely stripped the inside where the allen key fits when trying to take that damn nut off. Argh!
Would the bolt come off if I were to use air tools? I've got an air compressor but believe it only goes up to 100 - 150 psi.
Thanks in advance
Phaznet
phaznet is offline   Reply With Quote
Old 01-07-2013, 06:34 AM   #2
At this point you might be better off just cutting it off. You can buy replacement strut bars for about $25 each. Unless you can keep the bolt from rotating, an impact gun won't really help.
Old 01-07-2013, 07:42 AM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I came pretty close to stripping one of mine, but was able to get it off with an impact wrench. I'll probably need to replace it the next time I swap my suspension, but I can't find one for less than $50. Any suggestions where I (we) should look?
Old 01-07-2013, 10:21 AM   #4
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I had to cut 2 bolts off on my pass side when I first installed my ksport springs.
Old 01-07-2013, 10:22 AM   #5
I see what you mean. Back when I built Crashy's lift kit, I had to extend mine, by welding a longer bar to the ends. I kept lighting the grease cup on fire while welding them, so I ended up buying a bunch of extras for $25 each. I can't seem to find the place that I bought them from.
I might have one new set on hand that I never modified.
Old 01-07-2013, 02:44 PM   #6
phaznet
phaznet's Avatar
Thanks for the replies! I believe my only option at this point is to try an impact wrench, if that doesn't work I guess I'll need to cut the bolt off, but I don't have the tools to do that.
Also, when I installed the first spring I forgot to realign the air holes on the bump stop! can I get away with that or should I take it apart again to realign the holes?
Thanks again
Phaznet
Old 01-07-2013, 02:57 PM   #7
enviri
enviri's Avatar
Drives: 2010 Yaris
i used an impact wrench to take it off. easy.
Old 01-07-2013, 03:08 PM   #8
phaznet
phaznet's Avatar
was there also a ton of rust on your nuts and bolts?
Old 01-07-2013, 05:09 PM   #9
Soak it with pb blaster or another penetrating oil. Let it soak at least an hour...a day is preferable
From the back grab it with vice grip pliers and tighten the vice grips with pliers
Hit the nut with an impact wrench. Should break it free. Just make sure the vice grips are tight as humanly possible or the endlink will spin.
I've done this a dozen times w/o ruining the rubber seal on the endlink
Old 01-08-2013, 01:00 AM   #10
phaznet
phaznet's Avatar
Well the installation is now complete! I managed to get that bolt off by taking barber's advice (thank you), I used a vise grip to hold the back of the screw and untightened the the nut using an impact wrench.
The rear springs were a piece of cake compared to the front. I also installed the trd sway bar that I picked up last week.
Boy what a workout these last two days, my hands are killing me! I'm relieved that it's all done, but now I'm just worried that I installed everything properly. I'll ask the mechanic to check it out when I go to get an alignment done.
Thanks again for the help guys, I love this forum :) !!!
Old 01-08-2013, 01:58 AM   #11
yariseggvvti
Drives: Yaris Hatchieback
Hows the alignment now? Its off? I am going replace my front and rear suspension soon too. Tell me something about your mission? What else needs to look out? Thank you!
yariseggvvti is offline   Reply With Quote
Old 01-08-2013, 04:36 PM   #12
phaznet
phaznet's Avatar
The alignment seems ok, but it's recommended to get it done after you put lowering springs on. Tell you something about my mission? it took me 2 days!
As long as you follow the instructions there shouldn't be any issues. Once you've done one of the front struts, the rest is piece of cake (in comparison).
Old 01-08-2013, 09:12 PM   #13
yariseggvvti
I think if you don't touch the tie rod end it will be okay. I cant have my vehicle there for 2 days. My mission going to get all the parts and start early of the day. I am planing start after work on Friday night.
Phaznet, your next step is install all the bars in the vehicle and you feel the big difference.
Pushing hard in to the turns...
Old 01-09-2013, 09:41 AM   #14
Glad I could help
I ALWAYS do the front first as its the most prone to snafu's
Wait a couple weeks for an alignment. But if you pulled the bottom out while both strut bolts were in, but loose, the alignment will likely fall within Toyota specs
Old 01-09-2013, 10:08 AM   #15
That's great that they came off without having to destroy them. If anyone needs a new set, I found the new extra set that I bought back when I was working on Crashy's lift kit:
Old 01-09-2013, 11:13 PM   #16
phaznet
phaznet's Avatar
I've been driving my lowered vehicle for a day or so now. Everything seems fine with but there's only one minor issue. When I turn hard right there's a rubbing sound on the left front wheel.
I thought I might have bent something when trying to replace the strut, so I checked the wheel and pushed the metal plate behind the brake outwards a bit. It helped, but there's still a rubbing sound when I turn hard right.
Tires are 175/65R14
Old 01-10-2013, 09:48 AM   #17
Check your plastic fender liners for rub marks. Can't imagine those little tires would be rubbing but you never know.
Old 01-10-2013, 04:18 PM   #18
yaris2010RS
yaris2010RS's Avatar
is it a metal on metal sound or rubber on metal?
after doing something to the front of my car i had the same issue, tured out my brake dust shield would flex enough to rub the disk. a torch fixed that issue :) lol, jksjks, just bend it back a little
Warning - Broken control arm bolt! CB900F2 DIY / Maintenance / Service 460 08-23-2020 05:54 PM
bottom long bolt for alternator yaris9876 DIY / Maintenance / Service 5 05-24-2010 02:02 PM
FS CA: SS dress up bolt and washer AlainMikli Items for Sale by private party 9 11-05-2009 02:06 AM
