Old 01-08-2013, 03:47 PM   #1
Tatsh
Drives: 2009 Toyota Yaris LE
Possible starter issue?
Recently had a bit of front end damage where the bodyshop had to replace the rad, AC compressor and the bumper. Got it back last night and it started fine.
Got in my car this morning and starter wouldn't even turn over. Interior lights, low beams etc were all working. Tried jumping + pulling neg terminal off battery, and nothing.
Anybody have this problem before and/or know what the problem is?
Currently Done: Apex'i N1 Evolution Axle-Back, Tanabe DF210, Drag DR-31 (Rally Bronze) Wrapped in BF Goodrich g-force Sports, held together with Red Works RS Lug Nuts.
Tatsh is offline   Reply With Quote
Old 01-08-2013, 03:54 PM   #2
discomark10
Drives: 02 Yaris 1.5 T-sport
Did all the normal dash lights come on?
discomark10 is offline   Reply With Quote
Old 01-08-2013, 03:55 PM   #3
Tatsh
All the dash lights that are normally on are lit yea. Nothing seems out of the ordinary until I actually turn the key to start it, then nothing happens.
Old 01-08-2013, 04:03 PM   #4
discomark10
Could be a relay or wire or the starter itself
Old 01-08-2013, 04:48 PM   #5
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
Check the fuses on the power cable from the battery. Check starter fuse. Possible they damaged/forgot to tighten ground straps.
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
yaris voltage issue yaris2010RS DIY / Maintenance / Service 11 12-29-2012 04:20 PM
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 10:59 PM
heater control box issue DevilGirl DIY / Maintenance / Service 12 01-08-2010 03:45 PM
CONSUMER REPORTS : MARCH issue reviews '09 YARIS . gid General Yaris / Vitz Discussion 93 01-06-2009 04:10 AM
starter kill & horn help spechuy DIY / Maintenance / Service 0 10-20-2008 01:30 PM
