Old 01-11-2013, 04:11 PM   #1
david_827
Drives: 07 Yaris Sedan
Wiper Blades
Is there anyway to reposition the wiper blades?
For some reason the longer wiper blade on my sedan ends up getting stuck under the arm of the shorter one, then when i start the wiper blades the longer one ends up getting mangled. This has happened to me about 4 or 5 times over the last year and some change
i'll try to take a pic tonight to show you what i mean.
BTW i am using the Toyota OEM wiper blades.
david_827 is offline   Reply With Quote
Old 01-11-2013, 05:14 PM   #2
-Pop the plastic cap off of the wiper arm mounting point.
-Undo retaining nut that will be reveiled.
-Lift off wiper arm and reposition it a couple of degrees.
-Tighten down nut.
-Replace plastic cover.
Make sure you have the wiper arm lifted to full upright while working with the nut.
Old 01-11-2013, 06:41 PM   #3
david_827
-Tighten down nut.
Thanks! i will try this.
wiper blades walt101786 DIY / Maintenance / Service 9 03-24-2012 07:50 PM
Wiper blades .... Lafiro General Yaris / Vitz Discussion 81 02-02-2012 06:54 PM
Best Deal On Wiper Blades bobolinko General Yaris / Vitz Discussion 12 06-22-2010 02:15 PM
What kind of wiper blades? buyah123 DIY / Maintenance / Service 9 11-25-2008 05:25 PM
