Old 01-12-2013, 03:27 AM   #1
mariann
Drives: yaris 2007
catalitic converter problem
i have replaced my catalytic converter after getting p0420 cat blelow treshold problem.
it ws fine for 3 months and 5000Km. now i'm getting this problem again!
how can i check if something keep destroilng my cat?
i cant hear any backfire or something wrong there.
what can i do now?
last time i had it i needed to repalce also lambda sensor....
mariann is offline   Reply With Quote
Old 01-12-2013, 06:54 AM   #2
Ideally you need to measure your AFR (air to fuel ratio) to see if the engine is running particularly rich, which would plug the CAT over time. Some of the OBDII scanners can display AFR. They tend to have a lag, versus a real AFR gauge with its own sensor, but for just watching the AFRs, an OBD scanner would be fine. Over here, where many states have emissions testing for vehicles, repair shops have a tool that they stick up the tailpipe to measure the car's output. That is also a good way of seeing how the engine is running.
Old 01-12-2013, 03:26 PM   #3
mariann
Drives: yaris 2007
i can see the volts graph of the fuel air ratio. its running up and down from 0.1V to 0.8V...
we have this emmision yearly test with the prob inside the exhaust pipe wich masure 4 gasses.
the last time i did it i past the test fine with bad cat...
can it be a poor quality (but made in US with Chip Foos picture on the box) cat? or still something in my engine messing it up?
shuld i change sparkplugs or adding this fuel cleaner can to the tank?
Old 01-12-2013, 09:02 PM   #4
CoryM
Drives: 2009 5-door, 5-speed
The two most common causes of failed catalytic converters are:
-engine burning oil. This causes too much fuel for the catalyst to react with, and it melts.
-vibration. Such as a broken exhaust support bracket, or even just a rattling heatshield.
It is also very common for inexpensive aftermarket cats to only last a year or two; Even in good conditions. They use the bare minimum of the expensive catalyst materials to meet OBDII requirements (and sometimes not even that).
Yes, over-fuelling can cause cats to fail (same reason as the oil), but newer cars are much less likely to over-fuel that much without throwing a code.
Do you notice any blue smoke from the tailpipe when starting it cold? Any buzzing or rattling noises from the exhaust?
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 08:11 PM
New CAT Converter story.... jlift DIY / Maintenance / Service 14 06-03-2007 01:23 AM
High-to-low converter Kaotic Lazagna In Car Entertainment + Electronics (audio / video / alarm) 11 05-21-2007 01:18 PM
