Old 01-25-2013, 10:39 AM   #1
Kamikaze
Kamikaze's Avatar
Drives: Yaris TS NCP13 '02
catalyzer diameter
Hi everybody, I'm looking forward to change the stock cat with a sport-type cat so I need to know what are the inlet and outlet diameter measurements on my ncp13.
thank you!
Kamikaze is offline   Reply With Quote
Old 01-27-2013, 02:42 AM   #2
Andikilzz
Andikilzz's Avatar
Drives: Yaris 2011
thank you!
I think SARD Has release them... you could check on www.rhdjapan.com
www.sard.com
PLEASE WAIT UNTIL THE PROJECT IS FINISH
Andikilzz is offline   Reply With Quote
Old 01-27-2013, 09:58 AM   #3
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
It should be just under 2" iirc. The front pipe is double wall so you will have to put a few tack welds to secure the inner pipe to the outer prior to welding in the new cat. I do it all the time.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
AEM CAI Diameter? Golddeenoh Performance Modifications 1 06-27-2012 06:01 PM
Question about header outlet size and system diameter Shinare Performance Modifications 10 12-10-2010 09:27 PM
Megan Piping Diameter at3GG Performance Modifications 2 03-31-2009 04:23 PM
Quick-Link index for Yaris tire searches on TireRack WolfWings Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 09-16-2007 12:48 AM
Tire diameter list grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 06-04-2007 04:03 AM
