Old 01-28-2013, 07:44 AM   #1
my2sense
Drives: 2007 Red 5dr RS
Wheels spin while in neutral
Hey everyone, I observed the strangest thing today. I was doing an oil change and had the front jacked up. After finishing the change, I started up the car to let the oil circulate and both front wheels started spinning while my car was in neutral!
I can easily stop the spin with my hand/fingers but it will start spinning again when I let go off the wheel. It is related to engine speed and will rotate faster if I blip the throttle. Depressing the clutch stops the spin as expected.
Since the car is not in gear, how is it spinning? Anyone has any ideas?
Thanks
my2sense is offline   Reply With Quote
Old 01-28-2013, 07:48 AM   #2
seth_man
seth_man's Avatar
Drives: 08 Liftback
even though its in neutral, when the clutch is not engaged the input shaft is spinning, its just because there is some light resistance between parts inside the trans. perfectly normal
seth_man is offline   Reply With Quote
Old 01-28-2013, 02:49 PM   #3
jcboy
Drives: Sedan 07
perfectly normal, including the the clutch part--it should actually stop it from spinning. the spinning is, correct, a light resistance.
Old 01-28-2013, 03:16 PM   #4
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
it was just so happy that it had fresh oil that it wanted to go for a ride :D
Old 01-29-2013, 07:39 AM   #5
my2sense
Thanks everyone for the info. Never saw that happening on my other cars before.
Feedback on these wheels BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-04-2007 08:09 PM
