Old 01-31-2013, 10:44 AM   #1
Yarflana
Drives: 2008 Base Model
Springs...non-lowering...question
Ok, here is what I want to do. I DO NOT want to lower my car; but I want to replace the front struts and improve the suspension by doing so.
My question is should I just use the stock springs, or get new springs that WILL NOT lower the car?
Please advise....thanks a lot.
Yarflana is offline   Reply With Quote
Old 01-31-2013, 11:17 AM   #2
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
just replacing the struts will not lower the vehicle. It will improve handling, yes. But you will still have that soft spring. If you wanted stiffer handling, you could always go with a coil-overs. You can raise your car to stock height if you wanted.
Lets get this out the way first, what are your goals with this car and what is your budget?
-Derrick-
Old 01-31-2013, 11:27 AM   #3
Yarflana
Thanks ilikerice.
My goal is to make "bolt-on" improvements as stock items wear out. The car is a 2008 Yaris 3dr just turned 100K, so I plan to do the following:
1) Intake - done (K&N CAI)
2) Exhaust - purchased and to be installed this weekend (axle-back Megan Racing from Micro)
3) Tires and wheels - done (16x7, 205 16R50s)
4) Tint - done
5) Shocks - rear (purchases KYB and to install this weekend)
6) Struts - front (to be determined and waiting to see what lowering springs to get based on preventing rub with the tires...just want a little drop so about an inch or so all around)
7) Rear sway bar - purchased TRD and to be installed this weekend
8) Brakes - stainless brake lines, DOT 4 fluid, OEM size ported and drilled discs on front, pads and shoes, all from MICRO
9) Stereo system - TBD
Just about all the above will replace stock items and it is time. My budget is flexible.
Pat
Old 01-31-2013, 11:32 AM   #4
kou
Drives: 08 lb
Buy a set of Tokico HTS struts and shocks and then you can adjust how stiff you want your ride to be with stock springs.
Old 01-31-2013, 11:33 AM   #5
Yarflana
MICRO has these types of struts?
Old 01-31-2013, 11:33 AM   #6
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Swift springs offer higher rates with not much drop
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 01-31-2013, 11:34 AM   #7
kou
Drives: 08 lb
I believe so, if not they can get them.
Old 01-31-2013, 02:40 PM   #8
Which of these is the case? It's difficult to provide useful advice unless we know your goals, but I'd like to help.
(and THANK YOU for the business, we appreciate it)
For a 1" drop and a mild, 100% street-friendly spring that won't cause rubbing, the Tanabe NF210 or Eibach Prokit is your best choice.
Old 01-31-2013, 03:22 PM   #9
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I was about to ask the same question? ^^ there are plenty of springs to get around 1" of drop and increase performance
Old 02-01-2013, 11:54 AM   #10
Yarflana
Ok that really helps. Thanks. Sorry for any confusion I may be causing.
Old 02-02-2013, 11:30 AM   #11
Prokits are great
But just replacing the struts/shocks with performance shocks will increase the handling ability
Micro Image Lowering Springs Question sparkin88 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 12-30-2013 05:05 PM
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
TRD Lowering Springs. Alpha300 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 08-22-2011 11:36 PM
Swaybar vs. lowering springs eht13 General Yaris / Vitz Discussion 52 10-04-2010 07:59 PM
