Old 02-01-2013, 11:37 AM   #1
Iosous
Drives: Yaris Sedan
Sedan Spyder Projectors HID Upgrade
Hi! I have the Yaris Sedan Spyder Projectors and I want to change the stock bulbs to HID. Was thinking to 6K, you guys think that will be a problem? Is it safe to change to HID? Wont that melt or damage the headlights?
Iosous is offline   Reply With Quote
Old 02-01-2013, 02:57 PM   #2
Those were made for halogen bulbs and the reflector bowls are very small. You can run HIDs, but it'll most likely melt the housing or at the very least cause the reflective coating to start flaking off (meaning you'll lose light output).
Old 02-27-2013, 11:11 AM   #3
ukejamz
Drives: Yaris S 2007
I installed Kensun 6000K HIDs in my spyder projectors and they are fine. The only problem is that there is some glare above the cutoff line. I think I might know what the cause is but I will have to take it apart again to make sure....
ukejamz is offline   Reply With Quote
Old 02-27-2013, 11:20 AM   #4
Iosous
Drives: Yaris Sedan
What do you think is that glare? I havent installed mi hid yet
Old 02-27-2013, 05:03 PM   #5
Just the way the reflector bowl is made (since it was designed for halogen bulbs). Just like the OEM headlights, the reflector bowl is designed for halogen bulbs, which is why you get glare when you use HIDs in them. You can probably decrease glare by fabricating a shield that goes below the HID bulb to prevent some light bouncing off the bottom half of the reflector bowls (thereby bouncing upward and causing the glare).
Old 04-02-2013, 10:25 PM   #6
SolidGamble
SolidGamble's Avatar
Drives: 2007 Yaris Sedan
Maybe instead of HID, try PIAA bulbs or would those burn just as hot?
SolidGamble is offline   Reply With Quote
Why people choose a 5dr Liftback instead of a Sedan?? SimmZ General Yaris / Vitz Discussion 53 05-29-2007 10:28 PM
Toyota Australia releases YRX SEDAN. Sp33dY General Yaris / Vitz Discussion 1 08-01-2006 01:19 AM
