Old 02-03-2013, 09:40 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
crank grinding
little off topic
when you watch the videos of crankshaft grinding they usually just show the main journals
being ground. I couldnt find one where the piston journals were being turned. Are the piston journals usually stay in decent shape so they dont have to be ground?? I mean if the rod bearings take all the abuse...Are they as critical as the main journals??
yaris9876 is offline   Reply With Quote
Old 02-05-2013, 11:05 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
http://www.youtube.com/watch?v=y0NjkT0mqg0
Happy?
Yes the connecting rod journals need to be ground, and are as important (in not more so). If you over-rev an engine unloaded it is typically the conn rod bearings that will spin.
Cheers.
Old 02-06-2013, 06:18 AM   #3
bronsin
bronsin's Avatar
Not unusual for the mains to be fine and just the rods needing attention.
Grinding noise in reverse NickNickNick DIY / Maintenance / Service 14 03-15-2013 03:10 AM
Window crank on the floor after toyota servicing IMAMEX DIY / Maintenance / Service 5 05-08-2011 02:02 PM
NST Lite Crank Pulley camelll Items for Sale by private party 5 03-15-2011 08:57 AM
crank, fire, hesitate, crank, fire, run, gas smell twowheels General Yaris / Vitz Discussion 9 06-25-2009 07:11 PM
HELP! Removing manual window crank Astroman DIY / Maintenance / Service 8 05-26-2009 08:46 PM
