Old 02-04-2013, 07:13 PM   #1
theb
Drives: yaris
I want keyless entry system
Hi,
I can't find here on this site how to find if my yaris 07 hatchback has power locks. There is a button in between the front seats that opens and closes all 4 doors. I'm really tired of using key every day to open door and it looks like driver door lock is slowly starting to have problems. Very often I can't unlock the door at first time but I must move key left and right until it opens. Any info would be appreciated.
Also my car is close to 90k when should I do big maintenance, change belts and everything else?
I'm from Canada if that helps.
Thanks
theb is offline   Reply With Quote
Old 02-04-2013, 07:18 PM   #2
Originally Posted by theb View Post
Hi,
Thanks
If it has power locks, it will also have power windows. Aftermarket power locks with keyless entry is pretty easy to install and costs about $100.
Old 02-04-2013, 08:14 PM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
That's not strictly true (although it would be great if it were). My 07 LB has power locks and manual windows.
Old 02-04-2013, 08:40 PM   #4
That must be a Mexico thing. In the US they only come together.
Old 02-04-2013, 08:59 PM   #5
theb
Drives: yaris
It doesn't have power windows. But how do I find out does it have or not? I really thought that if this button locks/unlocks all four door that means it's using power to do that. If it doesn't then is there a way to add something to this button/switch that will lock unlock the car?
Old 02-04-2013, 09:01 PM   #6
If you do have that center console button (and it works), then you definitely do have power locks.
If you want to PM me the VIN for your car, I can tell you for sure, and also tell you if it has the keyless entry receiver.
Old 02-04-2013, 09:05 PM   #7
theb
Drives: yaris
Here you can see the pic. Http://media.caranddriver.com/images...s-1280x782.jpg
Mine only has lock/unlock switch.
Old 02-04-2013, 11:14 PM   #8
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
My '012 is a Japan thing, and has power door locks with keyed entry including a keyed hatch and old time hand crank windows which I really like.
Old 02-05-2013, 12:14 AM   #9
nookandcrannycar
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 45 02-15-2025 10:30 PM
Yaris L power windows and Remote keyless entry system with lock josevenezolano Third Gen Yaris General Discussion 12 06-04-2012 01:34 PM
keyless entry system DOMAV General Yaris / Vitz Discussion 6 08-21-2009 05:02 AM
