Old 02-06-2013, 06:41 PM   #1
filipetoyota
Drives: yaris
shock absorbers and springs????
which brand of suspension advise for my car go smooth? already used KYB excel-g and are very hard.
tell me someone knows what this pint damper springs in the front of my yaris 1.0 99/04 have a pint yellow car and the front this high.
filipetoyota is offline   Reply With Quote
Old 02-10-2013, 07:48 AM   #2
filipetoyota
Drives: yaris
Old 02-11-2013, 08:59 AM   #3
Yarflana
Drives: 2008 Base Model
What happened to your stock struts/shocks and springs? Did you remove them to lower the car? If so, the stock struts and shocks would soften things up, else you would need adjustable struts/shocks like Tokico reds.
Yarflana is offline   Reply With Quote
Old 02-11-2013, 01:08 PM   #4
filipetoyota
Drives: yaris
happens to have the dampers and springs source of origin and part of this evaluation will be high what's going on?? fit 5 fingers together in that basement here go 2.3 fingers together
what are the softest shocks i can get as replacement? Syroyizhka General Yaris / Vitz Discussion 16 03-21-2013 07:52 AM
TTE / Eibach springs + stock shocks & 15" wheels DieselPower Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 07-11-2009 02:42 PM
Adjustable rear shocks markitect Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 05-19-2009 03:58 PM
New 07 Yaris S need advice on 18's and springs OgDogg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 48 04-27-2009 09:50 PM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
