Old 03-16-2007, 03:18 PM   #1
JDMVitz
Obsessive Detailer
Drives: JDM
Tire size?
I'm planning to get 15x7 rims. What tire size should i go with? 195/55/15 or 205/55/15? It seems that to retain the overall circumference of the OEM tires, i need 205/55/15, but the tires i'm getting only comes in 195/55/15. Would i have a problem mounting them on?
JDMVitz is offline   Reply With Quote
Old 03-16-2007, 03:27 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
Oh god... this again....
15x7
205/55R15 or 225/50R15
I would not go 195's they would be too small
here is a link so you can see for yourself
http://www.1010tires.com/TireSizeCal...bmit&reset=yes
Old 03-19-2007, 10:28 AM   #3
JDMVitz
Obsessive Detailer
Drives: JDM
^ like i mentioned, i know 205/55/15 is closes to OEM specs. HOwever, using 195/55/15, i would still be in the tolerable limit. My concern would be, mounting a 195 width tire on a 7 inch wide rim? Would that pose any problem?
Old 03-19-2007, 10:32 AM   #4
Black Yaris
der Zeck
most likely, a bit of a stretch, but it would work, I would not do it, the 195's would cause too many problems
Old 03-21-2007, 06:38 AM   #5
MrMondayNite
Drives: 07 Yaris LB
When I first bought new rims for my old 01 Civic the dealer was selling these 15 by 7 in rims, which they claimed were Honda rims, but they were aftermarket rims with A peel on H sticker in the middle. Anyway my stock tires were 185/65/15 which the installer claimed would fit, he got them on but I knew I needed a wider tire. I then went and bought 205 size tires from tirerack and the fit was excellent. Like Black Yaris said I would definitely go with at least A 205 size tire. You say the reason you want to go 195 is because the brand tire you want does not come in 205, have you tried both tirerack and 1010tire. I have the stock tires and alloys which I believe are on a 5.5 inch rim, whenever I either come up with some extra cash or these tires wear out I plan on going with the 205's. But they won't look as good on a 5.5inch rim compared to a 7 inch rim.
07 Yaris Liftback (Commuter Car)
PWR Cold Weather Convience PKG'S Keyless Entry Rear Spolier Rear Bumper Protector Exhaust Tip Mud Guards OBX Sport Pedals Factory Alloys JDM Leather Shift Knob JDM Door Edge Guards
06 Civic Ex w/Navi (Other Car)
04 BMW 330 XI (Traded in)
03 VW Jetta GLX VR6 (gave to Dad)
01 Civic EX (gave to Mom)
MrMondayNite is offline   Reply With Quote
Old 03-21-2007, 11:03 AM   #6
boris13
Drives: 2007 Yaris Liftback, 5-speed
How would the 195's cause problems? That's only a 1.2 percent difference than the stock 185-60-15's.
boris13 is offline   Reply With Quote
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 06:29 AM
Need help with wheel & tire size rwseattle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 12-12-2006 01:10 PM
Tire size GabL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 10-18-2006 01:04 AM
Flat tire, totally ruin help David81 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-15-2006 01:54 PM
