Old 02-12-2013, 10:19 PM   #1
Yarflana
Drives: 2008 Base Model
RSR RAN-UP - who is using and do you recommend
http://shop.microimageonline.com/RSR...-RSR-ranup.htm
What are y'all's thoughts? Curious as to how to install (with oil change, or pour in, or what). Does it seem to help even if you are already running full synthetic oil?
Thanks,
Pat
Yarflana is offline   Reply With Quote
Old 02-12-2013, 11:31 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Interesting.
Old 02-12-2013, 11:35 PM   #3
Viperoni
Drives: 2005 Toyota Echo
I read the review on motoiq.com and they found some gains... they're a trustable site too, I might give it a shot this summer.
2006 Saturn Ion Redline
Old 02-12-2013, 11:43 PM   #4
People who use this say it works. I haven't tried it yet, but probably should. We do keep it in stock.
Old 02-13-2013, 09:48 AM   #5
Klink10
Klink10's Avatar
In regards to the Yaris, how much of the bottle goes in to the crankcase? I'm interested also.
Old 02-13-2013, 04:12 PM   #6
Yarflana
Garm, what are the instructions for use? I am wondering if you should only use when doing a fresh oil change, or if you can put in your engine at any point.
Please advise when you can.
Old 02-13-2013, 04:34 PM   #7
You can add it anytime, but because of the cost, I would add it at an oil change.
They say you can even skip an oil change, since it coats the interior surfaces.
FAQ page: http://www.rs-r.com/faq.php
Old 02-13-2013, 05:13 PM   #8
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
its it just an additive or extra lubricating properties or is it a form of micro lubricant that soaks into the metal and prevents stuff from sticking to the metal surfaces.
Old 02-13-2013, 05:23 PM   #9
"nano ceramics" -- read the FAQ page maybe?
Old 02-13-2013, 05:56 PM   #10
Golddeenoh
Golddeenoh's Avatar
why read when i have you to tell me stuff the words could tell me stuff about? :P
Old 02-13-2013, 07:27 PM   #11
alanwagen
Thanks,
Pat
Snake oil nonsense. save your money. It will not work. BTW, most everything else will wear out before your engine.
Old 02-13-2013, 09:23 PM   #12
mr_miles
Drives: 2013 Yaris
possible unintentional "how to train your dragon" reference lol
Old 02-13-2013, 09:30 PM   #13
Golddeenoh
Golddeenoh's Avatar
nope, intentional
