Old 02-12-2013, 10:19 PM   #1
Hershey
Thumbs up New used oil analysis for '08 sedan with SHELL syn 5w-20 and AC Delco PF 1233 oil ..
filter . The AC Delco PF1233 oil filter was used for back to back oil intervals . Always use Toyota air filter . Oil and oil filter in use from 10/13/12 > 2/7/13 . There were 56,368 miles on the engine when sample was took . Previous oil was SHELL synthetic 5w-30 with the AC Delco filter . The SHELL is $3.33 a quart and the PF 1233 is $4 . Looks like a keeper .
Old 02-12-2013, 10:44 PM   #2
Nice.
Old 02-12-2013, 10:48 PM   #3
Hershey
Thanks . The U.O.A.(s) make us feel confident since the head gasket replacement . Will get another U.O.A. in a year or so . Plan to get a sample from the '11 FIT soon . That has 21,000+ miles and uses 0w-20 . It's Pennzoil Platinum 0w-20 . Would try a 0w-20 synthetic ( Platinum or Amsoil ) in the the Yaris if not for the Toyota Platinum warranty ( 8yr. / 125,00 miles ) . Would extend the intervals to 7,500 or 10,000 miles like that of the FIT with the 1.5 ltr..
Old 02-12-2013, 11:21 PM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I am curious on whether or not each time you change the oil/filter combos you are trying you are also performing an engine flush to ensure that you have no residue from the previous oils?
Old 02-12-2013, 11:22 PM   #5
fnkngrv
fnkngrv's Avatar
What does the warranty have to do with making that change? Using any lubricant in a vehicle is perfectly fine and cannot void your warranty as long as it meets API standard which both of those do
Old 02-13-2013, 01:04 AM   #6
Hershey
No flushing . The warranty calls for 6 months or 5,000 miles . Sticking to it .
Old 02-13-2013, 03:02 PM   #7
Hershey
Buy the SHELL at BJs Wholesale by a case of 6 when on sale . On sale now if interested . Go here for details , http://www.yarisworld.com/forums/showthread.php?t=41685 .
Old 02-13-2013, 03:07 PM   #8
Hershey
This is the Technical Data Sheet ( T.D.S. ) for the SHELL synthetics from August 2011 . http://www.epc.shell.com/Docs/GPCDOC...1206121413.pdf .
Old 02-17-2013, 11:19 PM   #9
Hershey
Have a couple of the Toyota 90915-YZZF2 oil filters and installed one . It's weeping oil as a few others did in the past . The AC Delcos didn't . May remove it and replace it with the AC Delco or Puraolator One and top off the oil .
Old 04-14-2013, 05:14 PM   #10
robkay
Drives: Hatch
I see you made the jump for 30 to 20 weight after all. Looks like a great analysis.
I just used up the last of my dino oil and I'm poised to make the switch to synth at about 65k miles. Waited this long because I had several cases of Formula Shell that I had bought at about .$50-.80/qt. Pretty hard to beat that. I'm still getting basically sticker as far as mpg. In the mean-time, I've been picking up cases of Mobile 1 5w-30 whenever I found a great deal. But, now that I'm ready to switch over I see that the trend is toward 20w now. Sounds like you have become a believer. I'm in the Great Lakes region, so would be facing similar weather. Maybe I'll see if I can swap my 30 wt for 20 wt.
robkay is offline   Reply With Quote
Old 04-15-2013, 11:07 PM   #11
Hershey
Great price on SHELL ( conventional ? ) . Thanks , was impressed with the results . Would like the IRON to be a bit lower . So , going back to the synthetic 5w-30 for next 2 oil intervals to see if the IRON dips a bit . Will likely use Pennzoil Ultra 5w-30 for next O.C. and the 2nd could be ULTRA or SHELL synthetic 5w-30 . Then possibly get another U.O.A. after those . That'll likely be sometime in spring 2014 . Let us know how the SHELL performs for you . Their conventional is good . Used the 5w-30 a few times in the youth of the YARIS ( 20,000+ mis. ) .
