Old 02-18-2013, 03:48 PM   #1
Captain Slow
My Face Is Ridiculous
Captain Slow's Avatar
Drives: 2010 Toyota Yaris 3dr LB
Most N/A power?
Who's putting down the most N/A power and is there a dyno sheet showing it? Just curious.
Captain Slow is offline   Reply With Quote
Old 02-18-2013, 04:21 PM   #2
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
This is an interesting one....
I know that garm has said that with certain bolt-ons, he got 105 at the wheels and he has a dyno sheet to prove that.
I also know that if you have the green, you can go with higher compression pistons and get more power out of your N/A yaris. there has also been talk of head work and cams. I don't know if anyone has done all that and had it dynoed too.
I would like to get mine dynoed though I have no baseline to compare it to. I think I should be around the 105-110 range which isn't bad.
Old 02-18-2013, 05:05 PM   #3
Jason@SportsCar
This is mine before cams and head work. The current numbers are private.
http://www.yarisworld.com/forums/sho...&postcount=132
Old 02-18-2013, 05:27 PM   #4
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
i'd be surprised if anyone has more, although technically you probably could since Jason@SportsCar has to worry about staying in class.
Colin Chapman disciple
Old 02-18-2013, 05:44 PM   #5
Jason@SportsCar
A MI intake, new pistons and some bigger valves would crush it.
Old 02-18-2013, 06:13 PM   #6
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Yeah I'm 6hp or do below Jason with long tubes, a filter, and pulley. I'm sure I could get another 6-15hp with a cai and tune.
There is lots of power left on the table if you know where to look.
http://www.yarisworld.com/forums/sho...&postcount=168
Old 02-18-2013, 07:23 PM   #7
I'd like my tq around 130 ft/lbs or so. I couldn't care less about hp. lol
Old 02-18-2013, 08:37 PM   #8
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I made a non aspirated 110hp at the wheels, and can actually post a dyno chart to prove it.
This is how it ran on the dyno:
tooter intake manifold
1ZZ throttle body
SRI + BLOX velocity stack + dry element filter
Weapon R 4-2-1 exhaust header
all of the stock exhaust cats
Micro Image center exit axle back exhaust
Stock ECU
No tuning
regular unleaded 87 octane gas
Basically just the easy bolt on mods.
kuro-kuro, mga sarisaring katanungan xtremist Middle East 2740 01-27-2020 03:36 AM
Yaris Verso: Reset power window jam protection togo DIY / Maintenance / Service 3 01-10-2013 10:03 AM
DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS julienrl DIY / Maintenance / Service 1 08-31-2009 10:06 AM
