Old 02-18-2013, 05:47 PM   #1
stubbs157
Drives: 2010 Yaris Liftback
Liftback power lock not working
I have a 2010 liftback with factory power locks, and i live in new york so there is lots of cold, road salt and crap that gets everywhere. So over the weekend, my liftback lock stopped working. All the other power locks work fine, and there is a clicking sound still coming from the liftback lock, but apparently nothing is happening inside because it is not locking. Can anyone help me with this? I dont want to go to the dealer until I have to.
stubbs157 is offline   Reply With Quote
Old 02-18-2013, 06:04 PM   #2
Where in NY are you located?
The lock mechanism is shown below. When it is powered, the little plastic arm moves to flip a plastic arm on the back of the lock assembly, so one side or the other may have snapped if the lock was bound. Can you lock and unlock the hatch easily with the key?
Old 02-19-2013, 08:15 AM   #3
stubbs157
I am in western New York near Buffalo. Thanks for the tip I will check it out tonight. No it will not lock with the key either.
Old 02-19-2013, 01:01 PM   #4
If the key won't operate it, then it is internally bound or frozen. I would start with thawing it out with a hair dryer, and if that doesn't do it, then try spraying a little silicone lubricant into the lock and working it loose with the key.
Old 02-19-2013, 03:55 PM   #5
stubbs157
Ok thanks. thats kind of what I was thinking, it was about 40 degrees today and it still didnt work, I will try the hairdryer tonight, worth a try. I did spray wd-40 into the keyhole from the outside and still nothing...
Old 02-20-2013, 09:17 AM   #6
stubbs157
The hairdryer trick worked! Thanks for the help. Its odd because one day was almost 40 and raining so I figured it would have thawed but I guess not. My wife wasnt too happy about me taking her hairdryer though. Thanks again
how can I add a power lock switch? gabriel2012 DIY / Maintenance / Service 10 01-01-2011 08:08 PM
Power lock questions Taiyaki DIY / Maintenance / Service 22 04-22-2009 10:22 PM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 05:55 PM
