Old 02-21-2013, 05:32 PM   #1
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
Removal of the door panel
There is a rattling noise coming from my drivers side door every time I close the door or hit a bump. does anyone have a diagram or set of instructions for removing the door panel?
Old 02-21-2013, 05:52 PM   #2
There's a thread in the DIY section called something like "30 second door panel removal".
Old 02-22-2013, 01:33 PM   #3
Golddeenoh
Golddeenoh's Avatar
http://www.yarisworld.com/forums/sho...+panel+removal
found it thanks
Old 02-24-2013, 02:34 PM   #4
Golddeenoh
Golddeenoh's Avatar
well i fixed the rattle in the door, apparently this bracket had come lose where it has foam gluing it to the outside door panel.
i put a few dabs of super glue on the foam and pushed it back where it was, and for added redneck assurance, some duct tape.
Old 02-24-2013, 02:39 PM   #5
Superglue is only for non-porous materials. I would use Automotive Goop instead, which will do a good job of bonding it back in place.
Old 02-24-2013, 03:58 PM   #6
Golddeenoh
Golddeenoh's Avatar
its was dry rotted looking and torn, the duct tap should hold it together. since my budget for repairs right now is 0 i will have to stick with what i did instead of acquiring something else. thanks for the info :D
Old 04-26-2014, 10:01 PM   #7
Gil Gondreth
Drives: 07 yaris 3-door liftback
In case anyone is wondering if this is the source of your rattle, here's a video so you can compare the sound to what you've been hearing. https://www.youtube.com/watch?v=Dfza6yZjXUc
Gil Gondreth is offline   Reply With Quote
Auto Transmission removal artichap DIY / Maintenance / Service 14 10-23-2012 10:27 PM
99 Vitz Hatchback rear outer door handle removal deadalus DIY / Maintenance / Service 3 09-06-2010 02:02 AM
Removal of the Factory Integrated Source sqcomp In Car Entertainment + Electronics (audio / video / alarm) 7 08-24-2010 12:44 AM
Weight Savings - Removal, Reduction, Reminder.... TRD_Yaris Performance Modifications 17 08-12-2006 02:07 PM
