Old 02-24-2013, 02:50 PM   #1
Yarflana
Drives: 2008 Base Model
Lug nuts for RFP1s
Since I am looking to go with lighter weight wheels with the RFP1s (cutting 5 lbs a wheel), I am also looking to go with the best lug nuts I should in terms of weight and strength with keeping with the idea of shedding weight at the wheels.
They must have a wheel lock key vs. all the nuts using a 19mm (or whatever size) socket.
Any thoughts?
Thanks,
Pat
Yarflana is offline   Reply With Quote
Old 02-24-2013, 05:00 PM   #2
Klink10
Klink10's Avatar
Yep. Go to God Win racing (Mazda) and see what they sell. I got a set of those that require the special tool. Love them.
Old 02-24-2013, 07:29 PM   #3
Yarflana
Did you mean www.good-win-racing.com?
Old 02-24-2013, 07:39 PM   #4
Yarflana
Klink10, I got it from your garage, so no need to PM me back. Thanks for all the help.
Old 02-25-2013, 07:37 AM   #5
Klink10
Klink10's Avatar
PM sent
Old 02-25-2013, 09:31 AM   #6
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
I would not use Muteki whatever you do, I recently bought a set of those for my Kosei K1's and they blow
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 02-25-2013, 12:56 PM   #7
Lots of choices on my shelf and on my site. I use two-piece Rays.
Old 02-25-2013, 10:00 PM   #8
NJ Drive
Drives: 2012 Yaris SE
Care to elaborate why they suck? Just curious.
NJ Drive is offline   Reply With Quote
Old 02-25-2013, 11:53 PM   #9
enviri
enviri's Avatar
Drives: 2010 Yaris
i use mcgard spline drives and i'm quite happy with em
Old 02-28-2013, 04:21 AM   #10
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
If you want light weight go with the Volk Raicing duraluminum. The lock nut is a odd shaped seven sided nut.
Old 02-28-2013, 08:46 AM   #11
Yarflana
Ok here's the deal...finally got the RFP1s and they are the bomb like I imagined...pics to come soon.
I have the chrome steel lugs from Discount Tire with a spline drive key for each lug on all wheels.
I am curious whether spending $50-$100 to change to McGard or Volk steel (not going to aluminum) is really going to save me much in weight at all? I mainly daily drive, but want to have less weight, where I can make the most difference (i.e. wheels (already did that), battery, take stuff out of the car, pulley, take stuff out of the car, me lose weight, etc...).
Additional thoughts are appreciated.
Old 02-28-2013, 04:17 PM   #12
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
I had one of those aluminum lug nuts break on me, and I had to get the lug nut and lug blowtorched off my wheel. Get some wheel locks to keep those bad boiz on. I have these gorilla lug nuts that serve as wheel locks as well. U cant just use a key from similar lug nuts to take these off.
marlondog is offline   Reply With Quote
Old 02-28-2013, 04:27 PM   #13
Yarflana
@marlondog - actually, what Discount Tire gave me was a full set of Gorilla's, now that I looked at the key in my glove compartment.
I think I will leave well enough alone and not mess with replacing the lug nuts. They cannot make that much of a difference weight wise, especially since they are close to the center of the wheel.
Old 02-28-2013, 11:23 PM   #14
Viperoni
Drives: 2005 Toyota Echo
You're not going to feel the difference in weight from lugs.
Just get a good quality set.
I've used Muteki's for a couple years now on my Echo, and even through an entire season of swapping street for race tires at the track, they still look good and more importantly the threads are still good. Splines are in great shape.
I can't not recommend Muteki's - unless their quality has gone down.
I've used Gorilla's with good success too.
2006 Saturn Ion Redline
Old 03-01-2013, 08:57 AM   #15
X2
Been using mine for almost 8 years now on my '05. They are lighter than the steel ones for sure but you aren't going to notice any difference driving.
Old 03-08-2013, 06:18 PM   #16
7:34pm
Drives: 07 Yaris
there was a post on nasioc about light weight lugnuts, let me see if I can find it
Ray's lightweight lugs weigh just over 20 grams each. Stock units are about 60 grams each. So that's 150 grams saved, per wheel.
If you do the math, with 5x100 lugs on a 17" wheel, saving 150 grams at the hub is the mathematical equivalent of saving 8.3 grams at the drum of the wheel. With a 225/45/17 tire, 8.3 grams of rubber is contained in .1mm of tread, which is about half the thickness of a human hair.
So, in summary, you save more rotational inertia doing a powerslide and burning off a little rubber than you do by spending $150 on lugnuts.
7:34pm is offline   Reply With Quote
Old 03-08-2013, 10:26 PM   #17
Yarflana
Yeah, based on that logic, you should have lighter weight each day, but I would venture to guess it would be easy to offset that gain by filling up the gas tank.
Old 03-09-2013, 12:00 AM   #18
NJ Drive
His calculations are off... 150g at 100mm from center would be equal to 23.642g at the outer tread surface of a 225/45/17 tire with a 24.9785" diameter. Still minimal though.
FS: Mini Cooper 5 Spoke Wheels with Tires, Hubcentric Rings and Lug Nuts CTScott Items for Sale by private party 14 08-17-2012 11:18 PM
any substitute lug nuts for ray volks te37? gudboi182 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-17-2012 01:33 PM
Muteki Lug Nuts - Black - New in Package - $25 jtf1986 Items for Sale by private party 25 09-08-2011 04:07 PM
Painting the lug nuts......is it possible? pspeezy DIY / Maintenance / Service 6 11-01-2010 02:50 PM
LUG NUTS elmo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 05-01-2009 06:31 AM
